Originally posted by TaoMaas Just a thought...but are you inserting your film cartridge, then pulling the leader across to the take-up reel? I had someone show me that if I inserted my leader into the take-up reel first, then pulled the cartridge across and loaded it, it was MUCH easier to load my film.
Thanks for the tip! I'll have to try that. I've been inserting the cartridge first then dragging the film across the back. Because the magic fingers spin individually, and there was already some tension on the film, I found that the leader kept popping out when I would swing the film door shut.
Originally posted by gylfimag There should not be any need for a film changing bag when loading films, although you probably want to do it in the shade if there is strong sunlight.
Originally posted by stevebrot There is little (no?) need to use them for loading a camera.
Yep, I agree with you both. there isn't any
need, per se, for a film changing bag though there is a good reason to do so. I choose to use them because it allows me to sneak in an extra two frames on a roll of film that would otherwise be exposed by light while reloading. 26 for the price of 24 works for me, but I can understand why a lot of people would choose not to do it this way; it is a bit of a hassle. Even though the first camera I bought came with a film changing bag for free, half the time I just change film in the bottom of my backpack and it works just as well.
If there's a way to load film in daylight and still squeeze out an extra few frames, that'd be a tip I'd like to know.
