02-02-2014, 08:36 PM   #16
K David's Avatar
QuoteOriginally posted by boriscleto Quote
Sounds like a camera that should be sent to Eric.
Eric couldn't fix the issue. And that's fine by me because it's not mandatory for me.
02-03-2014, 08:46 AM   #17
ChrisPlatt's Avatar
QuoteOriginally posted by LesDMess Quote
BTW, since the KX - as well as others, uses two of the 1.5V batteries, you can also use a single lithium CR 1/3N or 2L76 or DL 1/3N or equivalent...
+1
I have used the 3V lithium CR1/3N cell without incident in all my cameras that normally use two 1.5V 44/76/357 silver cells.
Chris
02-05-2014, 05:09 AM - 1 Like   #18
thibs's Avatar
John, I never experienced such behaviour with mine and I never paid attention to batteries type (SR or LR I dunno).
The needle always reacts very quickly.
What I know is that the KX is a wonderful camera, only the MX is comparable to it and although I use the MX a lot more because of weight, my cherish my KX a whole lot more. I concur with others: it is worth a CLA: don't even think about it, do it !
02-05-2014, 06:51 PM   #19
johnha's Avatar
Thanks for all the replies, I've made a bit more progress. A new set of SR44's seem to have improved the metering slightly, it's still sluggish and fluctuates sometimes but it 'seems' more stable. After this I put some fresh LR44's in again and got similar results, so I can't conclude the SR44's have made a difference.
I've decided to get it CLA'd, although it might have to wait until my LX comes back.
John.
02-06-2014, 03:06 PM   #20
titrisol's Avatar
Location: In the most populated state... state of denial
I forgot.....make sure you get the camera "exercized" to get good measures
- Move the speeds dial back and forth a few times (to get rid of a possiblemicro layer of rust)
- Move the ASA scales back and forth a few times (to get rid of a possiblemicro layer of rust)
- Turn the meter on-off a few times (Just for fun)
- Shoot without film in the camera a couple hundred cycles in diffeent speeds
comparison, kx, meter, needle, pentax kx, reading, shutter
2 newbie Kx questions jjhenders Troubleshooting and Beginner Help 13 03-22-2011 05:35 PM
New Kx questions BirdDude007 Pentax DSLR Discussion 3 12-16-2010 07:49 AM
Just Got my KX - A few Questions krp Troubleshooting and Beginner Help 10 10-10-2010 11:21 AM
2 first day issues/questions - KX fizzbomb Troubleshooting and Beginner Help 17 09-10-2010 05:55 PM
All times are GMT -7. The time now is 04:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
