02-01-2014, 03:36 AM   #1
Pentax ES II - new batteries but no power
Hello, my name is Mario and I am new to this forum.
Well, I just bought an old Pentax Asahi ES II and at first sight it is in good condition but as I inserted the batteries nothing happened.
I switched it to automatic mode and pressed the knob for battery check but the needle of the light meter did not move. So I checked each battery separately - they are all good.
I also carefully cleaned the contacs of the batterie compartment with no result.
My question: Does anyone know this problem and has an idea how to fix it?
Thanks in advance.
Mario
02-01-2014, 06:11 AM   #2
Mario,
It could be anything - maybe a bad switch, or bad circuit board....could have been underwater - it's not easy to tell without knowing the history. Have you tried to open it or take it for servicing?
02-01-2014, 06:54 AM   #3
Welcome to the forum Mario!
I have often had this problem with older film cameras. In my case. the problem was poor contact due to a weakened spring in the battery compartment. I solved this by carefully pulling a little bit on the spring using some tweezers. This lengthened and stiffened the spring's travel to provide good contact once more. Be very careful because the spring could break. It may be safer to put a few folds of aluminium foil into the battery compartment lid for a similar effect.
Considering your cameras seems to be in good condition I hope this helps.
02-01-2014, 08:04 AM   #4
monochrome's Avatar
This may be obvious, but ensure the batteries are oriented correctly. The (-) faces inward.
02-01-2014, 10:59 AM   #5
A common problem with a lot of cameras of this age is that the wire connecting the battery holder has corroded and become detached. If all else fails carefully take off the bottom cover and you can see if this is the case.
02-02-2014, 01:33 AM   #6
Thank you all for your immediate replies.
Yes, I opened the bottom of the camera and there are no signs of beeing water or humidity in it. Furthermore the solder joints look quite well - each cable seems to have contact.
I carefully pulled the springs, like karpati told, unfortunately it does not help.
But I guess there might be a bad connection somewhere... Well, I measured the postive pole from the batteries connects the case of the camera. But where can I find the negative?
I tried to measure the resistance between the negative pole of the batteries and any single pin of the connector from the circuit board. All measures result in very high resistances. But I think there must be at least one direct connection from the negative battery pole to the circuit board. The problem is I can not find the cables which come from the battery compartment.
Does anyone have a clue about the cables coming form the battery compartment? For example the colors?
Regards
Mario
batteries, battery, es, es ii, ii, mario, no power, pentax, pentax es ii
K200d Battery Door, No Power stand alone, But works with Battery grip pento57mm Troubleshooting and Beginner Help 10 08-18-2013 11:24 AM
Pentax ES II Battery Compartment iht Pentax Film SLR Discussion 7 10-26-2012 08:03 PM
New lens but no time to play DaveHolmes Pentax SLR Lens Discussion 16 05-08-2012 01:40 PM
ES vs. ES II Stevopedia Pentax Film SLR Discussion 24 07-12-2009 05:49 PM
Pentax ES and ES II ads from the 70s Nesster Pentax Film SLR Discussion 6 03-15-2009 06:25 PM
All times are GMT -7. The time now is 07:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
