Well, it is obvious that the spring of the back curtain (or the second curtain if you will, I don't know what it was called since I am a Chinese, but I think you can understand me) is weaken with time goes, and it is not strong enough to touch off the reflex mirror climb up structure, which would invite a problem that seemed has nothing to do with it, which is your new problem. If you entight the spring ( the one of back curtain), the first problem will be definitely repaired, and I believe the second one will disappear as well.
My Pentax S2 once had your first problem, and several low speed shutter became B shutter, and after my adjustion of spring, the B shutter problem was solved at the same time with the first problem.
---------- Post added 02-24-14 at 08:22 PM ----------
Originally posted by Mingji Well, it is obvious that the spring of the back curtain (or the second curtain if you will, I don't know what it was called since I am a Chinese, but I think you can understand me) is weaken with time goes, and it is not strong enough to touch off the reflex mirror climb up structure, which would invite a problem that seemed has nothing to do with it, which is your new problem. If you entight the spring ( the one of back curtain), the first problem will be definitely repaired, and I believe the second one will disappear as well.
I'm sorry, the words in second line should be " the reflex mirror rebound down structure "
