04-30-2014, 08:33 PM   #1
JuanEstrada's Avatar
K2 diaphragm ring problem
Hi guys.
I got a black K2 from the bay and when you open the lens diaphragm, the lecture on the viewfinder changes, but that does not happen when you close it, or it happens very very very slowly. So, I checked the camera without the lens and found out that the lever that matches the lens it is not working properly, as shown in the video
that didn't happen before with my silver k2 and now it does... is there a way to fix this?
Thanks!
05-02-2014, 05:56 PM   #2
Someone please help. That seems like a quick fix but I don't want to break it.
05-02-2014, 07:11 PM - 1 Like   #3
gofour3's Avatar
QuoteOriginally posted by JuanEstrada Quote
I would email Eric and see what he thinks, he'll know for sure.
Pentax Camera Services
Phil.
05-03-2014, 10:07 PM   #4
Thanks, already did, let's wait for an answer... however, if someone knows how to do it, please let me know!
05-05-2014, 12:48 PM   #5
Giveaway winner!
MysteryOnion's Avatar
It might be possible to peek with a bright light and verify if the spring is still hooked to the ring or the screw that secures it is off or gone or the spring is broken?
If the ring was snapped back too hard, the loop end might have detached. It is possible to remove the mount ring and reattach.
05-05-2014, 06:07 PM   #6
Thanks a lot for the answer. I got an answer from Eric and he told me to put a little alcohol in the lever and if it works, then add oil. I worked like a charm!
diaphragm, k2, k2 diaphragm, lens
Backwards diaphragm blades jddwoods Pentax SLR Lens Discussion 4 12-11-2013 05:54 PM
Diaphragm problem Poliyoyo Pentax SLR Lens Discussion 4 05-09-2012 09:44 PM
DA 40 Diaphragm Blade Problem? Colorado CJ Pentax SLR Lens Discussion 31 12-26-2010 01:40 AM
? K2 K2-DMD focus screens Moe49 Pentax Film SLR Discussion 4 10-18-2010 06:25 AM
K200D Problem with aperture ring g-kun Pentax DSLR Discussion 7 08-09-2008 08:13 AM
All times are GMT -7. The time now is 08:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
