05-07-2014, 02:10 AM   #1
Pentax MX mirror stuck up
Hi
The mirror on my Pentax MX is stuck in open position. It is not the foam making it stuck because when I push it down it goes back up. The shutter works. I can see it open and close but the mirror just doesnt wanna go diwn. It thinks it is in live view mode.
Any ideas how to fix it?
05-07-2014, 03:40 AM   #2
Has it ever been cleaned? I would suspect some oil has dried off and made a sticky surface somewhere in the mechanism.
05-07-2014, 04:16 AM   #3
Moe49's Avatar
The mirror gets stuck during the longer shutter cycles, right?
Like 1/2 sec or 1/4 second. But does not get stuck in the up position when you use a faster shutter speed, like 1/500 or 1/250?
Have you tried rotating the shutter speed dial from slow to faster speeds? That often works to 'un-stuck' the mirror and return it to its normal position.
Likely a case of the mirror timer in the bottom of the camera is gummed up with goo, and needs to be cleaned.
Time for a CLA.
05-07-2014, 02:34 PM   #4
Feels like it affects all shuttespeed. Sometimes it will drop down when I push it and fire.
Just got it from an auction so its never been cleaned I think.
Anyone know which part of the mechanism needs to be fixed? Im quite handy so its no problem but I dont know where the fault is located.
05-07-2014, 04:42 PM   #5
gofour3's Avatar
QuoteOriginally posted by striker_ Quote
It will need a CLA, which includes removing the old foam/seals and replacing them.
There are DIY kits on the internet, otherwise Eric or a closer Pentax tech is recommended.
Phil.
mirror, mx, pentax, pentax mx mirror
Help, Pentax ME Super's mirror is stuck up ... spystyle Pentax Film SLR Discussion 15 06-29-2014 12:43 PM
Mirror is stuck up, shutter not working (Pentax 645) ShootingTheWinds Pentax Medium Format 5 01-16-2011 08:42 PM
MX mirror stuck up - is one of you knowing the remedy? Rense Pentax Film SLR Discussion 8 11-12-2010 04:37 AM
Pentax LX mirror stuck up in AUTO only iht Pentax Film SLR Discussion 26 09-29-2010 11:37 AM
MX Problem - Mirror Stuck Leslie P Pentax Film SLR Discussion 3 11-04-2007 02:28 PM
All times are GMT -7. The time now is 12:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
