08-20-2014, 11:24 PM   #1
Help - Spotty bokeh using Pentax tilt/shift
Hi, I've been shooting with my Pentax MX for about 2 years now... great camera, great lenses, great results.
I recently followed an online tutorial on how to make a tilt/shift lens on the cheap.
I tore apart an old 50mm f1.7 prime that was in perfect condition, but just to be sure I gave it a good clean while it was dismantled.
So, now I have a good as new, f1.7 Pentax tilt lens... BUT...
I've gone through a couple of rolls of c41 b&w film only to find that while the areas in focus are clean and clear, the areas where there is bokeh (ie. out of focus areas) have a distracting, random spotting. This effect gets worse the more out of focus the area, and in some cases looks like I've shot through a car window while it's pouring with rain.
I've never seen anything like this and I can't seem to find any information about it online. I'm aware that by making my own lens there is always a risk of something weird/wonderful happening, I'd just like to know what is going on so I can minimise it, or indeed use it to my advantage... Knowledge is power after all.
Thanks, Luke
08-21-2014, 01:44 AM   #2
Ole
Ole's Avatar
I'm speculating here, but I'd think that a tilt lens would have to have a much larger image circle than the one the camera otherwise requires. By using a 24x36 lens as a tilt lens on a 24x36 camera you get all sorts of optical aberrations. It would be interesting to see how a medium format lens would perform.
08-21-2014, 05:29 AM   #3
Nesster's Avatar
Somehow there's quasi-focus on some dusty element in/on the lens?
08-21-2014, 05:48 AM   #4
QuoteOriginally posted by Ole Quote
I agree that both for tilt and shift, the lens circle must be larger, in particular to accommodate the shifting of the lens and thus the lens circle. Also, as I understand it the lens is ground and designed a bit better to extend the center area out to the lens' edges again to assist in the shifting and in this case the tilting also. Using this lens on a cropped sensor would help in this regard, since the sensor being smaller would make the lens' circle appear to be larger thus simulating a real tilt/shift design.
QuoteOriginally posted by Nesster Quote
I am thinking that there is some tilting applied to this image and thus with the focal plane moved from its normal position, other items are now in focus - or at least in play within the lens itself.
08-21-2014, 10:03 AM   #5
...or the sensor is seriously filthy.
08-21-2014, 02:58 PM   #6
FrankC's Avatar
Can't be the sensor since the MX is a film camera.
Did you process the film yourself or take it to a lab? I'm wondering if this is a result of poor processing or handling. I think an easy test of the lens in various positions should help to figure out what's going on.
08-21-2014, 03:26 PM   #7
QuoteOriginally posted by FrankC Quote
My bad
---------- Post added 08-21-14 at 03:27 PM ----------
Looks like an enlarged finger print.
08-22-2014, 06:12 AM   #8
QuoteOriginally posted by Lukemx Quote
Could you please point me to this article ? I would be really interested in making one myself, providing I have the tools to do it ?
As for your problem.... well, I have absolutely no idea what could have caused it
bokeh, bokeh using pentax, f1.7, focus, lens, pentax, pentax help, spotty, steve, tilt / shift, tilt/shift
Tilt + Shift Option for Pentax! Scootatheschool1990 Pentax SLR Lens Discussion 9 08-24-2013 11:45 AM
For Sale - Sold: Arsat Arax mc 2.8/80mm tilt/shift lens for Pentax chadchaumont Sold Items 3 07-13-2013 03:04 PM
Tilt shift Bcrary3 Photographic Technique 29 05-13-2013 04:22 AM
Nikon to Pentax K adapter for Samyang tilt shift? captainbert Pentax SLR Lens Discussion 8 04-23-2013 01:26 PM
DIY tilt/shift lens for Pentax K? alspe Pentax SLR Lens Discussion 9 09-18-2012 02:57 AM
All times are GMT -7. The time now is 11:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
