11-01-2014, 12:55 AM   #1
Show me the error of my ways.
I have a roll of tri-x 400 that has three frames with this interesting streaking in the emulsion. It was developed at the 1 Hour Hi-Jacked Kitchen lab with DD-X. Normally, I would call this a swing and a miss (it's a crappy shot anyway), but only three frames show this issue. I did my best PP to make the problem as obvious as possible. I have soaked and washed and dried these frames two more times. No change. I'm not really interested in recovering these shots, but I would like to know what causes this. I would hate to miss a keeper do to operator error.
I forgot the Pentax content. MX, SMC 50 1.4 and the Pentax strap that came with my K-3.
11-01-2014, 01:19 AM   #2
The only thing I can think of is that the film wasn't loaded on the reel perfectly and the emulsion side was touching the non-emulsion side in some places.
On second thoughts though.... although the streaks are not dead straight, they seem equally spaced at the top. Do the start of the steaks match up with the sprocket holes?
11-01-2014, 01:27 AM   #3
The three frames show slightly different patterns. One is more vermiculated than striped. This was the worst one, so I use it as the example. The streaks don't line up with the sprocket holes in any obvious way. Having said that, it is a 35mm frame, so a good lawyer might argue otherwise.
If I were to load the spool improperly, could I potentially trap developer?
11-01-2014, 01:53 AM   #4
QuoteOriginally posted by Dukeatoakland Quote
Yes. The developer which is in contact with the emulsion becomes exhausted which is why you agitate every so often, If the emulsion was touching another part of the film, those contact points would be underdeveloped.
11-01-2014, 02:59 AM   #5
Is there any chance poor agitation technique could cause this?
11-01-2014, 03:23 AM   #6
tvdtvdtvd's Avatar
Are the bad images sequential or staggered on the roll? I as well think the fault is underdevelopment, most likely caused by a poorly
wound spool. Have you shown the negative to the lab?
11-01-2014, 03:36 AM   #7
Digitalis's Avatar
It looks like you used Poor agitation during the stop bath/fixing phases. Mineralised water can sometimes leave residue when you don't squeegee the film after washing it properly, this is why for the wash phases I prefer to use de-mineralised water for greater clarity in my images.
11-01-2014, 03:43 AM   #8
The three bad frames are 18, 19 and 20 of 36. The "lab" has seen them. The "lab" looks suspiciously like me (and is currently wearing my pants).
---------- Post added 11-01-14 at 03:51 AM ----------
I use distilled water for everything but the long rinse at the end. Is this a mistake?
When you say "Poor" agitation, are you suggesting I am over or under working the film? I generally get good results. When I get off results, I am suspicious of my technique - but I can never put my finger on it.
11-01-2014, 03:55 AM   #9
I don't think is a problem of the dev process, because (for what I can see, and maybe the problem is my screen), lines are only in the highlights of the image. Are there also lines on the dark part of the picture?
Another point: in the rinse part, do you use normal soap? do you also rinse with flowing water?
11-01-2014, 04:08 AM   #10
The lines do make it to the shadows, but they were hard to bring out in PP. If you hold the negative at just the right angle to the loupe, you can see them continue weakly into the trees.
I use a Photo-Flo 200 bath after an eight minute flowing water rinse. The flowing rinse is from the tap. Everything else is distilled.
11-01-2014, 04:24 AM   #11
Oh ok, thank you for the additional info. So I agree with Digitalis, it could be a problem of the fixing bath. Did you also wash with water between the development and the fixing? Maybe some developing chemical was on the film when you poured the fixing bath inside the tank..
11-01-2014, 04:25 AM   #12
I can see the lines going into the shadow area in your print. I really don't think its a rinse issue or even a stop or fix issue. I still think it was a problem loading on the reel. Do you use plastic or steel reels?
11-01-2014, 04:28 AM   #13
I do a distilled water stop bath between developing and fixing.
---------- Post added 11-01-14 at 04:31 AM ----------
QuoteOriginally posted by Vendee Quote
I use a steel reel. I have botched the loading before. However, it wasn't subtle. It was a pull the roll off and do it again level botching.
11-01-2014, 04:32 AM   #14
phoenixvision's Avatar
Is it possible there was an issue with the paper? Did you try developing them again?
11-01-2014, 04:35 AM   #15
I was thinking about it too, but in this case, shouldn't be affected all the frames on that side? I mean, the problem should be on the frames that are facing and not (or not only) to the consecutive ones.
error, film, frames, issue, miss, reel, results, steel, stop, water
Weekly Challenge Weekly Challenge #282 - Show Me The Light atupdate Weekly Photo Challenges 42 05-03-2014 07:15 AM
Help me complete the short side of my collection TroutHunterJohn Pentax SLR Lens Discussion 20 03-13-2014 01:38 PM
How do I get Lightroom to show me what lens my photo was taken with? ChopperCharles Digital Processing, Software, and Printing 25 02-24-2014 09:15 PM
Macro Show Me the Aphids! eaglem Post Your Photos! 4 12-29-2012 08:39 PM
Can anyone show me the non-macro capabilities of the da 35 macro limited? skawi Pentax SLR Lens Discussion 2 04-19-2008 06:54 AM
All times are GMT -7. The time now is 11:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
