Hello there. Today I developed my latest roll (tmx 400 pushed 1 stop) and this came out...
I had ZERO issues while shooting this roll, I only had a locked mirror issue in the last few frames, here is the picture
But the rest of roll is like the first picture. You can't notice in the picture, but behind that 'dirtiness' it's clear the roll has been 'properly' exposed because I can barely see the images I have taken, and the frames all separated as normally.
I was told that this could be caused by using tap water to rinse the roll after the fixer, but to be honest, I have been using the same water in my previous rolls and I have never had an issue like this before.
I did a good developing process because I can perfectly read KODAK TMAX 400 in the perfs area (and also means the roll couldn't get light leaks, right?)
After I was told about the tap water, another person said it could be a shutter issue, it might leak light from there (not fully closing, I guess).
Have someone seen this before? I really don't know what it is, and since taking the camera to the service shop is expensive where I live, I want to have an idea of what the issue may be before taking it there.
Thanks in advance.
