01-07-2015, 11:09 PM   #1
K1000 - film advance lever clicking, film wont budge.
Hi everyone,
I apologise if this is not the right place to be posting this, and for my poor use of terminology.
I've recently come into possession of a K1000. It's been working fine, but on a few rolls of film it has gotten stuck.
These particular rolls are quite sticky you could say and take some force to wind in-between shots.
They will then reach a point where they seem to be too hard to advance for the camera, and the wind lever will just click over, as if the gears do not have enough traction.
That is to say I am able to cock the shutter but the film will not advance.
Does anyone know if this is a common problem, and what causes it?
Is it easily fixed?
Thanks for reading.
01-07-2015, 11:39 PM   #2
Not a Number's Avatar
You can download a version of the service manual for the K1000 here:
http://www.pentax-manuals.com/markroberts/k1000_man.pdf
The section on winding mechanism is at the end of the document. It says if the spring-type clutch is defective you have to replace the entire wind shaft assembly.
01-07-2015, 11:41 PM   #3
Photo Forum Moderator
photolady95's Avatar
One question I'll start with. Are you sure you loaded the film correctly?
01-08-2015, 05:30 PM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by photolady95 Quote
My thoughts as well.
01-08-2015, 07:50 PM   #5
arnold's Avatar
Have you come to the end of the roll?
01-11-2015, 09:22 AM   #6
gofour3's Avatar
QuoteOriginally posted by hiddenvibe Quote
Hi everyone,
Is it easily fixed?
Thanks for reading.
If it’s not a loading issue, then it could be the film advance lever.
I had a similar issue with a KX and Eric had to replace the film advance leaver system.
I would email Eric.
Phil.
01-20-2015, 04:52 PM   #7
The OP appears to have disappeared into thin air!
advance, film, film advance lever, k1000, k1000 film advance, lever, rolls, stuck, wind
K1000 won't advance film juliakb09 Troubleshooting and Beginner Help 3 02-15-2014 10:23 AM
K1000 - Sluggish Film Advance severalsnakes Pentax Film SLR Discussion 4 01-04-2014 11:26 PM
Incorporation of Film Advance Lever Torakira Pentax DSLR Discussion 7 06-03-2012 12:39 PM
6x7II Film Advance Lever Wont Wind adprousa Pentax Medium Format 2 03-08-2011 07:43 AM
ME Super film advance lever problem! Thursday Pentax Film SLR Discussion 8 09-12-2007 12:07 AM
All times are GMT -7. The time now is 08:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
