I develop my own films (although mainly stuff shot with my 645). That 1.4 should be fun to go shooting with (and don't discount the p30 either. It's ugly as sin, but I tend to think of it as an mx with AV. It can also take DA lenses, although you'll be limited to program mode)
Don't get the Patterson tank, get the AP one instead!! The Patterson tank is misery heaped upon misery to load films into it. The AP one is much nicer (in every other regards, Patterson is usually better than AP stuff).
I'd probably recommend buying some really cheap rolls of film first (expired from eBay, or cheap kentmere stuff). Whilst the canisters can take two rolls, limit yourself to one at a time initially. Expect the first couple of rolls to be a disaster. My advice would be to try one roll. Once that has failed horribly, use that film to practice loading the reels in sunlight. Then practice a few times with it in the bag, and then attempt the second roll.
If you get tempted to shoot a roll of colour at any point, and don't want to jump into developing c41 just yet, I highly recommend the 'develop + hi res JPEG scan' from snaps photographic in Bournemouth.
As for change bags, get the large size! You can cope with smaller ones, but having more room in the bag makes thing far less stressful initially!
I'd recommend this at a minimum:
- changebag
- ap tank (might as well get the universal one, 2x135, or 1x120)
- 650cl measuring cylinder
- 2x 1 litre bottles (only needs to hold as much as the cylinder. You could use any plastic bottle, but make sure you label them clearly with do not drink!). Use to store your fixer (and stop bath if you go that route)
- funnel
- two pairs of film clips (Patterson clips are nicer)
- film cannister opener
You can add more equipment as you go, but that should be enough to get started (and will make the whole process pain free).
Firstcall photographic are a decent 1 stop shop for all this stuff. Their postage is a little steep for one or two items, but reasonable for a large order.
Have fun!
---------- Post added 02-08-15 at 10:26 PM ----------
Originally posted by walliswizard Looking at some of what you guys have on here, one or two bodies seems to grow into a couple of dozen+ over time!
There's an easy solution to that problem. Just make sure your next body is a 645 or 6x7, and skip everything else in between!
Although obviously you'll need a z1-p for da lenses, and an espio mini/uc-1 for portability, and an LX (because why wouldn't you?), and a 110 auto just to complete the collection!
