Hello, all,
Is there any particular way in which the M42 adapter (genuine Pentax version) should be mounted? Should I screw it on the lens, and then mount the lens as if it were a bayonet-mount lens, or should I mount the adapter to the body and then mount the lens? I am using a ZX-M body.
Thanks,
Glen
