05-09-2015, 10:07 PM   #1
Pioneer's Avatar
Blurry View thru Viewfinder on my MZ-S
Like the title says.
My Pentax MZ-S produces beautifully focused pictures.
The problem is that what I see in my viewfinder is very blurry regardless of how much I adjust the diopter. I can bring the viewfinder items like brackets and center spot into clear focus but not the image I am focusing on.
I will probably send this off to Eric for his attention but thought I would check here to see if anyone has any ideas regarding possible cause. If there is something simple that I can check I may try that first.
05-09-2015, 10:52 PM   #2
sbc
Have you inspected the mirror? Is it dirty? It may even be misaligned but of course there is no way for you to check that.
05-10-2015, 07:28 AM   #3
Marketplace Reseller
dcshooter's Avatar
The focus screen might be out of position. Re-seating it is a pretty trivial task and it's worth giving a try before you send it off.
This thread contains instructions for replacing the screen, but the images are equally useful for seeing how the screen bracket works. It releases with a little latch in the front and drops down, then you can re-seat the screen. and click it back into place. While you are in there, you can blow out any dust that is above the screen. Make sure to wear nitrile or rubber gloves while performing the procedure or you risk smudging the screen.
05-10-2015, 02:40 PM   #4
Pioneer's Avatar
Thanks, that is actually a good idea dcshooter. I have done a few Katzeyes in my day but this did not even cross my mind.
Ok, after fiddling around it does seem better but is still a little blurry. But it's good enough now for me to continue working with it for awhile.
BTW - Your DIY article is very well done.
05-11-2015, 05:00 AM   #5
dcshooter's Avatar
Can't take credit for one! It was done by PF member Zivelot.
QuoteOriginally posted by Pioneer Quote
check, mz-s, viewfinder
My view on these have changed since I was a newbie years ago, what's yours? aleonx3 General Photography 78 12-21-2014 04:19 AM
*ist blurry viewfinder repair replacement korimako Maintenance and Repair Articles 4 11-11-2011 04:52 AM
my Pentax Kx viewfinder is blurry? WA-surfer Pentax DSLR Discussion 18 10-12-2010 05:51 PM
*ist blurry viewfinder repair replacement korimako Pentax DSLR Discussion 3 05-28-2010 11:36 AM
Hands-On Comparison MZ-5n vs MZ-L(6) vs MZ-S k100d Pentax Film SLR Discussion 37 02-01-2009 11:25 PM
All times are GMT -7. The time now is 02:06 PM. | See also: NikonForums.com, part of our network of photo forums!
