Originally posted by stevebrot My question too...
May I suggest some way to make the filmstrip and camera sensor parallel?
The light source is a house hold 100 watt equivalent CFL bulb, I also have a 100 watt incandescent I might try for scanning colour film. I use 2 layers of diffusion material I bought of B&H. Originally I had made a smaller box but it heated up quite a bit with an incandescent inside. I had also tried a flash bulb, but it seemed wasteful and it's a lot easier to focus with a continuous light source. (Edit, this is the diffuser material I used
http://www.bhphotovideo.com/c/product/185687-REG/Lowel_IP_72_IP_l_Frost_Gels.html )
I would love suggestions!
FWIW, this was only going to be temporary, but I can't seem to really notice distortions in my scans so I have put off dealing with the problem. I know it's not perfect, but I've really enjoyed the results out of it so far.
I've considered mounting some kind of quick mount plate to a track on the plywood for quick adjustment and repeatable results. I also have a friend with a CNC laser cutter, v3 (?) might get cut out of MDF with alignment holes etc if I get fancy.
