Show Printable Version 11 Likes Search this Thread
06-01-2015, 04:33 AM   #1
bobbotron's Avatar
dslr film scanning
I've been having a lot of fun with my spotmatic, am planning on learning how to develop my own film to reduce my costs. Along with this I'm hoping to start scanning my own photos. I have a K3 and a 100mm macro lens and am a pretty active wood worker, so I imagine I could probably make some kind of jig that holds the camera and film a fixed, adjustable distance, and would incorporate a flash mount. I was hoping some of you fine folks could provide me with some inspiration for what these dslr film scanning set ups look like. I remember someone posted one a while ago on this forum, but I can't seem to find it now.
06-01-2015, 04:51 AM   #2
I will be facing the same challenge. I might use my Canon G12 with its 1:1 macro
06-01-2015, 04:59 AM - 2 Likes   #3
Dartmoor Dave's Avatar
My own DSLR film copying rig is made from the innards of a cheap Ion film "scanner" -- one of those things that use a crappy built-in 5MP camera and produce lousy results. I've retained the LED light source and the circuit board to power it, and adapted it to work with a DSLR and macro lens.
Here's the rig:
And a couple of sample shots:
06-01-2015, 09:48 AM   #4
I like the high-keyish result which seems very suitable for the subject matter.
06-01-2015, 11:49 AM   #5
Would you recommend creating a rig like this as opposed to purchasing, say, the Jumbl scanner (which does 35mm at 16 megapixels)?
06-01-2015, 12:45 PM   #6
Here is a link to photos & explanation of my homemade rig: Old Photo Shooting Rig - darylkottwitzphoto. It works fine.
06-01-2015, 02:43 PM   #7
QuoteOriginally posted by WDibble Quote
The Jumbl type scanners just use a tiny compact camera sized sensor and a very basic cheap lens, so the output is quite poor. A well constructed and carefully used DSLR rig will give dramatically better results, for a lot less money since you're likely to already have many of the components you need.
An old enlarger base as the camera support and a light box as the light source is one way quick and easy way of doing it.
06-01-2015, 03:29 PM - 1 Like   #8
K David's Avatar
Here's my process for both small and medium/large format:
Since recording those, I've changed to an 85mm Rodagon enlarging lens for digitizing. The results are significantly improved and truer to the film. Also, that makes getting a frame reduction to fill the APS-C sensor size easier. I also added a tube of M42 macro tubs (with some step-up and -down rings) to close of the space between the front of the lens and slide holder. This improves image contrast. Lining the tubes with felt eliminated the very minor hot spotting issues I've have on exposures longer than 1/4 second (for very under exposed slides or overexposed negatives.)
Here are some recent results:
One nice thing about digitizing with a DSLR is that you can pull it back a bit and keep the image frame if you'd like.
06-01-2015, 04:44 PM   #9
I have setup similar to K David. Here are two threads I posted about camera-scanning my negatives.
https://www.pentaxforums.com/forums/107-film-processing-scanning-darkroom/258...-film-pix.html
This thread was posted when I was still using a K-30. Now I have a K-3 with a FluCard. Same basic principles apply.
https://www.pentaxforums.com/forums/107-film-processing-scanning-darkroom/294...can-films.html
I've moved from Aperture to Capture One too.
06-01-2015, 07:11 PM   #10
wissink's Avatar
I'm developing an interest in film. Maybe it is nostalgia, as my dad had a K1000 when I was a kid. I'm considering trying a k1000 / kx etc. I'm keen to learn. I found a couple of negatives of my grandparents from the late seventies. I think he died in 79.
My first attempt was on friday. I didn't have a lot of time so avoided the complicated setups and simply taped the film to a window. I reversed the toning in LR and removed dozens of white dots / lines. Could be dust maybe. I used the 35 ltd macro lens. I'm fairly happy with the results. The downside is that I had to tilt the tripod to get this lens close enough, so my lens may not be perpendicular to the photo. This would've affected sharpeness I'm sure. I also had to use a slightly higher ISO/Shutter.
EDIT: I also chose B&W because I'm not great with colours. It also had a yellowish tone I couldn't discern its accuracy. Maybe ashen grey is more appropriate for someone who died before I was born..?? Maybe not.
06-01-2015, 09:01 PM   #11
You can "cancel" out most tints with correct adjustment of white balance, white tint point, grey tint point, and black tint point.
06-02-2015, 12:04 AM - 1 Like   #12
vrolok's Avatar
Find below a picture of my set-up.
You can see it is very simple! I am using my K-3 + Tamron 90/2.8 AF. I cutted a hole (this case 24x36) in a thick paper (from a shoe box), where I glued a thin folded paper which serves as a guide for the film. I painted in black the edges of the paper. Then, as you see, I use a tripod, and I made a sort of long lens-hood, black again, which goes all the way down to the film. Best is the uniform bright back-light for which I use nothing but my mobile phone! Maximum brightness, screen always on, and I believe the name of the app is "WhiteScreen", downloadable from the Google Play Store.
It all works great, very fast, no prob whatsoever. Two examples, below.
Cheers
PENTAX Q  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
06-02-2015, 04:26 AM   #13
Bookmarked that breakdown. I keep seeing 85 and 90mm macros. My Pentax is my film shooter. My digital is a Canon T5i, which is an APS-C with 18MP, so I don't think that's an issue, but I only have a 60mm f/2.8 macro, and its all I can afford. Think that will work?
06-02-2015, 06:17 AM - 1 Like   #14
bobbotron's Avatar
Thanks for all the replies! This gives me hope - I think I'm going to buy a slide holder from B&H and see what I can get up to with wood... Will post my results back here!
06-03-2015, 06:04 AM   #15
wissink's Avatar
I'm using a 35 Macro with a 1.5 crop sensor = about a field of view of 52.5 mm on FF. Your 60 x 1.6 is about 96 mm fov on FF. It'll work fine .
dslr, dslr film, film
Some thoughts on DSLR scanning of negatives, processing, and film (with pix!) 6BQ5 Film Processing, Scanning, and Darkroom 34 03-01-2021 05:44 PM
DSLR scanning whojammyflip Film Processing, Scanning, and Darkroom 24 03-03-2014 08:28 AM
"Scanning" film with DSLR and macro lens zoltan1983snapper Pentax DSLR Discussion 5 07-10-2011 11:04 AM
Bruce Barnbaum: b+w film exposure and film scanning dj_saunter Film Processing, Scanning, and Darkroom 4 07-07-2011 07:16 AM
Film Newbie - Q's about film choice, development and scanning Ryan Trevisol Film SLRs and Compact Film Cameras 22 05-12-2011 07:44 AM
All times are GMT -7. The time now is 03:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
