Originally posted by grhazelton I've recently acquired a Super Program which looks to be in fine condition. It does need new light seals and the frame counter won't fully reset when the back is opened. Other than that and a few rubs on the base plate it is lovely.
The film counter problem is perhaps just a nuisance, but still..... Is this repair something I could attempt, or should I send it off to Eric?
Thanks!
The old foam may have jammed the reset projection. Try dropping some lubricant into the reset slot in the door channel. I dip a toothpick into a light oil like WD40 to avoid overdoing it.
