Originally posted by stevebrot
Have you tested the hot shoe? It is easy enough if you have an ohm meter or continuity tester. Test the center spot against the hot shoe rail. The sync switch is normally closed. Set the shutter on 1s and release the shutter. The circuit should open shortly after the shutter release is pressed and close as the shutter closes.
no, I have neither available. But 1s wouldn't work because flash sync time is 1/60s and only then the sync switch would open.
I have disassembled the hotshot and found it a little corroded, looked all in all a bit sketchy. Talked with the seller, he took it back. I'm now looking for a new spotty F or esii.
