07-16-2015, 07:02 AM   #1
DamienL's Avatar
Replacement Light Seals Very Tight (Will It Harm My Camera?)
I had my light seals replaced and they look ok, however when I close the back it's very tight. It closes, but I have to squish it closed...And when I open the back, it doesn't pop open - I pull the rewind knob and nothing happens, I have to open the door myself.
I don't mind this if the seals work, but I don't know enough to know whether this is ok with my camera - is really tight foam strong enough to bend the back of the camera? Or otherwise damage it?
Thanks in advance, I appreciate any help I can get!
It's a Pentax ME if this is useful.
07-16-2015, 06:50 PM   #2
QuoteOriginally posted by DamienL Quote
New seals are not intended to create such a tight fit. The door may be unaffected, however the camera latch may become damaged beyond use from too much stress. If you can get hold of a pair of small scissors that have the two ends curved upwards, you can go along the top of the seals until the door fits normally. Or, another option would be for you to take the camera back where it was repaired and tell them what the problem is. They should be willing to make it good (hopefully) for no charge. If not, I would go elsewhere for service in the future. I hope this helps.
Tonytee
07-16-2015, 09:10 PM   #3
A Proud PENTAXER !!!
fwcetus's Avatar
QuoteOriginally posted by Tonytee Quote
You might also try pushing along all of the edges of the door (when closed), gently but firmly pushing the edges of the door more deeply into the seals, to see if they might become easier to close the door against. (That is, press the door into the seals a bit yourself, rather than just letting the hinge and the latch do all the pushing.)
However, if the seal is just overly thick or stiff, with no sign of improvement, I'd take/send the ME back for a redo. (The seals on a new ME didin't act quite the way you describe.) Light seals are supposed to be light-tight, and not necessarily air-tight or water-tight..
07-17-2015, 09:03 AM   #4
DamienL's Avatar
Thank you very much, Tonytee and fwcetus!
I think I will go back and see if he'll fix it. It cost as much as the actual camera body, it should be done well!
07-18-2015, 03:50 PM   #5
ChrisPlatt's Avatar
A good repairman will use the right thickness for your model camera, not whatever he happens to have lying around.
If you'd rather try re-doing it yourself correctly Jon Goodman has inexpensive precut kits for many model cameras.
Chris
camera, light, light seals, me super, pentax me, replacement light seals, seals
Question About 67 Light Seals Linemrkr Pentax Medium Format 5 02-06-2015 06:26 PM
Replacement light seals?? grhazelton Pentax Film SLR Discussion 8 06-13-2014 12:40 PM
MX light seals rob_k20d Pentax Film SLR Discussion 10 06-04-2014 02:06 AM
light seals JLW Pentax Film SLR Discussion 16 08-08-2013 06:08 PM
How to check camera seals for replacement? LeDave Pentax Film SLR Discussion 15 09-07-2012 07:02 PM
All times are GMT -7. The time now is 11:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
