07-17-2015, 11:11 PM   #1
Pentax zx-50 image problem
Hi guys so I'm very new to the photography I just recently bought a used Pentax zx-50 it was working fine at first but now I have this issue. The issue is when I'm looking for an image to shoot through the lense absolutely nothing appears. ( ex: if I put an Apple in front of my camera I won't see the Apple to shoot or anything besides blackness.) THE LENSE COVER IS OFF ..I really need help or if I'm doing something wrong or if it's some setting I'm overlooking.
07-18-2015, 12:29 AM   #2
Not a Number's Avatar
Sounds to me like the mirror lockup problem. These cameras used plastic gears on the mirror and shutter mechanisms which crack with use/age. The replacement motor have a metal gear but the stock of replacement parts may have dried up. If you search the forum there is a thread and post on replacing the gear yourself and on post lists the part number and website in Germany that you can order a suitable replacement (metal) gear.
Another weakness is also with the built-in flash lifter - on part - also plastic - tends to split so the flash won't popup. There are a thread or two on DIY fixes for this too.
You can order this part from USCamera.com Worldwide Parts. but it will eventually break again.
07-18-2015, 06:52 AM   #3
6BQ5's Avatar
Let's confirm this is a mirror motor issue. Can you describe the sound of the camera when you fire off a shot? Is it different now than it was when you first got the camera? The mirror motor makes a very distinctive whiney sound when its busted compared to when it is working.
07-18-2015, 09:31 AM   #4
Or just take the lens off and look in the mirror box to see if the mirror is up or down. It could be stuck on a "gluey" mirror bumper. It which case it will come unstuck with minimal force. If it is locked up the mirror won't budge.
07-19-2015, 07:13 AM   #5
I actually somehow got it to show an image but I'm sure it will malfunction again, I've been looking at forums as well and then noticed that the film advances w/o taking pics. (Ex/I put new film in and it advances to exposure 2, I changed the settings and it advances 4 if I turn it off, advances to 6, turn it on again 8...I found ppl say it's the motor plastic gear, gears for mirror and shutter.. etc. So are these multiple gears that need to be replaced? As well my flash does not flash.
---------- Post added 07-19-15 at 07:15 AM ----------
QuoteOriginally posted by 6BQ5 Quote
When I got the camera I have heard and actual capturing a shot abt 2times, I press the button to snap a shot but only my film advances. Film advancing is the only noise my camera makes.
advances, apple, camera, film, flash, gears, image, issue, lense, mirror, motor, pentax, pentax help, pentax zx-50 image, photography, shot, sound, troubleshooting, zx-50
Pentax ZX-5n mirror lock a common problem? SuperAkuma Pentax Film SLR Discussion 36 09-12-2020 09:45 AM
Pentax ZX-M film problem saab_princess_21 Troubleshooting and Beginner Help 20 07-13-2016 09:50 AM
Pentax zx 50 KathyP29440 Pentax SLR Lens Discussion 4 03-30-2015 03:14 PM
Problem with my ZX-50 midwest 1953 Pentax Film SLR Discussion 2 05-25-2008 06:51 AM
Pentax MZ-50 (ZX-50) with SMC-M lenses derius Pentax Film SLR Discussion 8 02-28-2008 06:12 PM
All times are GMT -7. The time now is 07:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
