08-20-2015, 09:06 AM   #1
bobbotron's Avatar
Issues developing Delta 3200
So I just developed my first roll of delta 3200 this morning. I've had a lab develop in the past, with decent results. Shot at 3200 ISO, developed with DD-X, 1+4 for 12.5 minutes. It seems over half the roll came out pretty much clear, ie totally not exposed. I was shooting at night on the street w/ street lights, mostly f2 with a shutter speed around 1/125 or 1/250, it's possible I misjudged the EI of the scene, I'll see if I can scan the clear ones tonight, if there's anything there.
Any thoughts on what I did wrong? It took me a month or two to shoot the roll, and it's been pretty warm out, perhaps the film went off, or I didn't develop it for long enough?
08-20-2015, 10:17 AM   #2
titrisol's Avatar
Location: In the most populated state... state of denial
It is very hard to say without seeing it.
Is half the roll contiguous or frames skipped with a pattern?
My gut tells me you didn't develop it properly.
When doing night photography a bit of overdeveloping doesnt hurt, as in many cases you are guesstimating the exposures.
Delta 3200 is quite forgiving, and if you slow down agitation (once very other minute) and increase the time to 15-20 min you can get better results as the highlights will not bloom too much
08-20-2015, 10:25 AM   #3
bobbotron's Avatar
Yeah, I'm wondering if I didn't mix the dev correctly - not enough developer? The weird thing is that some of the shots looked well developed. I'll see (hopefully) tonight how they scan.
08-20-2015, 11:26 AM   #4
titrisol's Avatar
QuoteOriginally posted by bobbotron Quote
If youhave some well developed frames then teh developer was good... it is more an dunderexposure issue
Also if the film had enough space, the frames will look perfectly clear, if they were toouching they will look "milky" or even white
Also, for how long did you fix?
08-20-2015, 01:11 PM   #5
bobbotron's Avatar
QuoteOriginally posted by titrisol Quote
Fixed for 5 minutes, with new Ilford rapid fixer.
I don't *think* the film was wrapped too tightly... but it's possible?
The film was reasonably clear at the end - I'll try to post up photos tonight.
08-20-2015, 06:14 PM   #6
bobbotron's Avatar
So I think I didn't roll it correctly, I'll have to be more careful next time. I did have a hard time loading it at first, so then loaded it from the other side. I've noticed sometimes it seems to get harder to load about halfway through, like there's drag on the reel, despite that I don't see anything on it... It's a paterson plastic reel, I've been having some issues loading it but it's only developed about 10 rolls tops, so I can't see how it would have worn yet. :/
Here's a few photos.
First a few that sort of turned out
This one strangely fades out halfway
Totally blank
Unremarkable photo, but I'm pretty sure I took a number other with the same EI and settings and they were blank.
08-20-2015, 06:31 PM   #7
Not a Number's Avatar
Looks like streaks at the sprocket holes on the third scan. Usually a sign of over agitation.
08-21-2015, 01:39 PM   #8
titrisol's Avatar
the totally blank frams look like the developer could not reeach them (aka too tightly wound)
The rest seem fine
08-21-2015, 02:02 PM   #9
bobbotron's Avatar
The rest seem fine
I'm guessing that's what happened. Looks like I need to sacrifice a roll of film and practice winding. Any tips for how to avoid this with Paterson reels?
08-21-2015, 02:04 PM   #10
titrisol's Avatar
Patterson reels must be clean.... scrub them from time to time using you mother'sin law toothbrush and some baking soda
And they must be REALLY DRY for them film to easily slide
09-21-2015, 01:18 PM   #11
bobbotron's Avatar
Arg, I did it again, this time with Delta 400! I'd done a roll of Holga 400 earlier in the day, perhaps the reels weren't clean or dry. :/
09-21-2015, 01:59 PM   #12
Jonathan Mac's Avatar
f/2 at 1/125 or 1/250s sounds right at 3200 in a city with lights.
If they're completely blank but with good exposures right next to them then it sounds to me like there's a problem with the camera A development problem wouldn't do that - all the frames would likely be affected to some degree.
Paterson reels are good but the leading corners of the film can jam in them and cause problems. To avoid this, snip the corners off at 45 when loading. Just a couple of milimetres will do the trick.
09-21-2015, 02:14 PM   #13
bobbotron's Avatar
QuoteOriginally posted by Jonathan Mac Quote
Yeah, it might be that spotmatic is acting up. We'll see, I have a roll of 3200 dev'd with a reliable K1000, will see how that turns out...
09-22-2015, 04:26 AM   #14
You need to look at the frame numbers and the other rebate printing.
If that is uniform and good the loading and development are good.
The camera may have a problem lens off back open fire shutter 1/60 to 1/500 you should see a light other side of camera every firing at begin and end of shutter run.
Loading Patterson reels is like riding a bike, you need to fall off enough.
You need to fix for longer for the plumes from sprocket holes, refix if they disappear it is indicative.
You need to avoid posting positives we need to see the negative image. You need to learn to look for printable details in your shadows on negatives. If you have clear film no shadow details.
Don't worry keep trying, but night photography is difficult try a wet city street scene before more difficult scenarios.
01-04-2016, 08:35 PM - 1 Like   #15
bobbotron's Avatar
I finally developed a roll of this stuff with success! I think most of my past failures were due to contamination from the chalky dust of gloves I was wearing.
I wish someone made a true 3200 ISO black and white film, the low range of 3200 is fantastic and quite limiting.
delta, issues developing delta, roll, street
Delta Winged old4570 Macro Photography 10 11-01-2014 05:34 PM
TriX 400 pushed or Delta 3200? dugrant153 Film Processing, Scanning, and Darkroom 12 05-20-2011 06:43 PM
Pentax 645 + Ilford Delta 3200 @ 1600 = awesomeness dugrant153 Pentax Medium Format 26 04-11-2011 03:54 PM
Ilford Delta 3200 - shoot at 800-1600, develop at 1600? dugrant153 Film Processing, Scanning, and Darkroom 15 11-08-2010 02:27 AM
Amsterdam, Delta 3200, M6-60 Erasmo Post Your Photos! 4 10-25-2008 05:30 PM
All times are GMT -7. The time now is 06:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
