Originally posted by LesDMess I only shot the Fuji Tungsten version which I believe will be similar in color characteristics. If so then it will come out with a bluish tint but should be easy to fix with a little post work. If you are planning to use a projector then that is a different matter altogether.
No, no projector. A few prints, probably, if the shots are worthy.
---------- Post added 09-14-15 at 11:48 AM ----------
Originally posted by tuco The digital files they send you will most likely be auto color balanced by their process unless their is an option opt-out of that, I suspect.
I'll be hoping for this. You're thinking the auto balance will correct the blue shift?
