09-23-2015, 04:41 AM   #1
Pentax MV without eyecup
Hello all,
I just learned yesterday, that a Pentax film SLR without eyecup might mess up the light meter reading because some light gets inside the viewfinder if an eyecup is not used, thus underexposing photos.
I already managed to shoot a film without a cup, so does this mean all my shot are badly exposed?
09-23-2015, 06:40 AM   #2
Don't worry you should be ok.
09-23-2015, 09:44 AM   #3
Welcome to the Pentax forums!
This is a potential problem for most SLR cameras having auto-exposure. Normally, your face shades the eyepiece enough to prevent throwing the meter off. The main problem is when shooting on tripod under bright conditions. Pentax made a slip-on eyepiece blind for use under those conditions, but usually it is enough to simply place your thumb across the opening.
09-24-2015, 09:59 AM   #4
filmamigo's Avatar
Yes, the issue is the cap, not the cup. If you are shooting on a tripod with a bulb release, you probably won't have your face pressed to the camera -- skewing the meter.
09-24-2015, 12:18 PM   #5
I shot Pentax film cameras from the 1960s and never had an eyecup. I wear glasses, so my eye is back a bit from the eyepiece. I had few problems, but with the sun low and behind me, enough light could enter the eyepiece and cause an under exposure, especially on a Spotmatic. With B&W or color negative film this wasn't enough to be a problem, but with slide film it wasn't good.
09-24-2015, 08:37 PM   #6
QuoteOriginally posted by TomB_tx Quote
It is more of a problem with stop-down metering, particularly when shooting adapted M42 lenses in Av mode on K-mount cameras on tripod. At narrower apertures the light coming in the eyepiece can easily be much more than that coming in through the lens.
09-24-2015, 11:31 PM   #7
Thank you all for a response.
eyecup, film, light, pentax, pentax mv
Pentax Asahi Spotmatic vs Pentax MV haydenmtaylor Troubleshooting and Beginner Help 20 11-23-2014 03:14 PM
Exposure for asahi pentax mv slr film camera 35mm? Bigtimedreamer333 Troubleshooting and Beginner Help 4 09-30-2014 01:42 PM
Pentax MV 1979 Nesster Pentax Film SLR Discussion 3 03-26-2011 08:45 PM
Eyecup or magnifier eyecup on K10D Rnovo Photographic Technique 3 03-21-2010 06:31 AM
Pentax Asahi MV glaciersofice Pentax Film SLR Discussion 5 10-22-2009 09:46 AM
All times are GMT -7. The time now is 10:41 AM. | See also: NikonForums.com, part of our network of photo forums!
