10-13-2015, 11:41 AM   #16
Could be bad scans, or light fogged at the lab (because it's so uniform).
10-13-2015, 02:05 PM   #17
Got the negatives back. The first half-dozen frames look to be exposed more or less correctly. All were afternoon shots, sun at my back.
The next several, all taken at the same place, from mid-morning to noon, overhead sun, were all overexposed to varying degrees. The elephant photo I posted earlier is from that batch. Some were worse, some about the same.
The shots after that were taken at various times, mostly afternoon, and are exposed correctly.
It seems to me that one of two things happened: either my light meter temporarily went haywire, or my shutter speed is off at around 1/250 or 1/500, which is where most of the overexposed shots were taken.
Sound reasonable?
10-13-2015, 08:27 PM   #18
UncleVanya's Avatar
I thought the lens filter flare theory made sense. Particularly in overhead sunlight without a hood.
10-14-2015, 01:56 AM   #19
Not a Number's Avatar
The filter may need cleaning. Since I had a UV filter on my Takumar 50mm f4 macro lens I didn't bother with the lens cap. However I noticed that when I was shooting back-lit subjects the contrast would go way down vs with light behind me or using a macro flash. I cleaned the filter and everything was fine. It had picked up a slight haze probably from air pollution.
10-14-2015, 06:03 AM   #20
The dirty filter idea could have merit. Thinking of driving into the sun with a dirty windshield, I could see the same sort of effect in these shots. It doesn't look dirty, of course, but it could be environmental haze. I'll give it a cleaning and see what happens.
10-14-2015, 11:30 PM   #21
You need to look at the neg
Bad flare will have silver in all the shadows
Normal shots will have some zone0 clear film shadows
Lens hoods are not optional if the yellow ball gets into a lens...
Generic rubber allows a drop unto concrete if you are lucky!
filter, kx, meter, photos, results, tri-x
HI,I am with K5ii, I am just new here fuenqing Welcomes and Introductions 14 03-30-2015 08:24 AM
Hi I am Andy and I am new here. AndyHSP Welcomes and Introductions 3 12-18-2013 03:07 PM
Da* Squeky Am I over reacting? JeremytheIndian Pentax SLR Lens Discussion 6 09-21-2012 08:10 PM
Landscape Fog-K5 filters--Panos--Am I forgetting something? charliezap Post Your Photos! 8 09-11-2011 04:40 AM
K-x over D5000. Am I wrong? asinla Pentax DSLR Discussion 102 06-17-2010 03:16 PM
All times are GMT -7. The time now is 05:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
