10-12-2015, 06:18 PM   #1
Film gear have any value still?
So a co-worker (Canon shooter) came across a box of Pentax gear (a relative passed away a number of years ago and the spouse is moving from the family home). He, being aware that I'm using Pentax, brought the gear to work to see if I wanted it and if so, for how much.
I don't see alot of value here for my personal use but am not shy hold on to stuff as maybe I'll find the time or be more inclined to have this gear later.
I've included a list of the main gear (various old filters, 3rd party flash, shutter release, etc not listed).
The bellows might be fun someday. I've a macro lens though and am not sure I'd use an M42 bellows for much.
The copipod looks cool, but again, what am I ever going to use it for?
The 4 lenses I have in K mount and the 1.4 are both yellowed.
The extension tubes, same as the bellows.....and again, m42.....
I have 4 film bodies currently but these bodies have both been kept well.
As such, I don't mind spending $50 or something if they just want them gone, in hopes that someday I might find the gear worth having.
I'm not inclined to undervalue someone else's gear though, without at least being honest in that regard.
Anyone see much here that might have value and would make it worth is while to ebay this (either together or piecemeal).
Thanks.
M42 bellows with book
PENTAX Bellows Unit II (M42) reviews - Pentax Camera Accessory Review Database in original box with sleeve.
Copipod
PENTAX Copipod reviews - Pentax Camera Accessory Review Database in original case with booklet.
asahi pentax lenshood SP SV SLA lenshood in case and in original box.
m42 35mm 3.5 in stamped (Takumar 3.5/35) case
S-M-C/Super/Auto Takumar 35mm F3.5 Reviews - M42 Screwmount Wide-Angle Primes - Pentax Lens Reviews & Lens Database
m42 135mm 3.5 in stamped (Takumar 3.5/135) case
m42 50mm 1.4 (qty 2)
Case with extension tubes (AOCO)
Pentax Aoco Asahi Optical Company Genuine Case FOR Extension Tube | eBay
Pentax AF16 Flash in sleeve type case with booklet
Asahi Pentax Ref-Conveter in case and original box
Asahi Pentax Correction Lens adapter in original box
Asahi Pentax Spotmatic (qty 2)
SMC Pentax stamped case (SMC Pentax 4/50
10-12-2015, 06:25 PM   #2
Aaron28's Avatar
sure there is value...stuff like this is bought n sold constantly.......
10-12-2015, 06:46 PM   #3
UncleVanya's Avatar
The bellows is good for macro work. Get an m42 flanged adapter for use just with the bellows. Depending on the camera you have you might use an m42 extension tube to be sure you have the clearance from the pentaprism.
The lenses can be used on any slr with the right (original) Pentax adapter.
10-12-2015, 06:49 PM   #4
Assuming that all of the gear are in good working order, I'd say there is about 300 to 400 CAD, possibly a little more for the entire collection if you were to sell them piecemeal.
10-13-2015, 01:24 PM   #5
Bob from Aus's Avatar
Warning warning warning Get a T mount to go onto the bellows. The pentax adapter will lock on and you can't get the bellows off the camera because the flash protrudes forwards - film cameras were flat
10-13-2015, 03:30 PM   #6
Thank you all.
I will show him this thread and let him decide. I am guessing he'll take it all back for the potential value.
10-13-2015, 08:10 PM   #7
UncleVanya's Avatar
QuoteOriginally posted by Bob from Aus Quote
I specified the flange type adapter which doesn't lock and suggested using an m42 extension tube to extend past the pentaprism. Also the entire m42 mount on the bellows easily separates with the turn of a thumb screw allowing the bellows to be removed and then the small ring can be turned to remove it from the adapter. The pentax adapter would be useful for using the lenses directly without the tubes or bellows.
I own this same bellows and use mine with the Pentax adapter and extension tubes. I should grab a flanged adapter to use to make it easier, but what I have works.
---------- Post added 10-13-15 at 11:15 PM ----------
QuoteOriginally posted by Mistlefoot Quote
Thank you all.
Remember that value is for gear that is in great condition, the lenses may have fungus, the apertures may be sticky, there may be scratches... value may not be there.
10-14-2015, 11:14 AM   #8
Everything I've looked appears to have been well looked after.
10-14-2015, 12:59 PM   #9
dsmithhfx's Avatar
Cosmetics aside, you can't really know what shape it's in until you've put film through it.
10-14-2015, 02:54 PM   #10
osv
macro lenses and bellows can be stacked together.
testing for lens decentering... if you put a mirror on the table, and center the camera directly over it, the sensor should be pretty parallel to the surface of the whatever graphic you are shooting.
when pentax ff digital comes out, that could be very handy for wide lenses.
you are eventually going to move from film to digital?
yellowing can be fixed, it's a question of testing to see which lenses have the least amount of decentering, i would hang on to the 50/1.4's.
that glass is a bit weak on the sides on my a7r, k-mount 35's or the fa35 are much better.
goodwill donation.
10-14-2015, 06:53 PM   #11
Bellows is m42. Macro is K mount. That would mean conversion on both side etc......or using one of the m42 lenses.
I haven't shot film in probably 10-15 years.
None of the equipment is mine to hang on to.
The case would be handy as I've a K mount 135 3.5 and although I haven't tried, it'd probably fit.
Basically, I next see the co-worker on the 16th and unless he just wants it gone I doubt he'll give me everything that I think has value for next to nothing. Will see.....
QuoteOriginally posted by osv Quote
goodwill donation.
10-14-2015, 08:02 PM   #12
UncleVanya's Avatar
Reverse mount the lens. Could be fun to try.
10-14-2015, 09:40 PM   #13
QuoteOriginally posted by dsmithhfx Quote
Oh sure you can. You can visually inspect lenses for fungus, lens separation, oil on the diaphragm and so on. Turn the focus ring to feel for the smoothness of the lens' operation. Turn the aperture ring to see if the diaphragm is opening and closing properly.
As for the camera body, fire off the shutter at all speeds and listen to see if the shutter speeds are accurate. Leave the film back open and fire off the shutter to see if the shutter curtain is working properly. Check inside the mirror box to see if the foam seals and bumpers are working properly or if they need replacing. If the camera has a meter, test the meter against another camera/meter.
People have been buying used cameras probably from the day after the camera was invented and it would be most unlikely that you'd have the chance to 'put the film through' any of them before you buy.
10-15-2015, 07:52 AM - 1 Like   #14
gofour3's Avatar
I have tried using the equivalent Takumar lens case on my K series lenses and none fit properly. The wider K Series 52mm filter diameter lenses are usually too wide for the Takumar 49mm cases.
Phil.
10-15-2015, 09:24 AM   #15
titrisol's Avatar
Location: In the most populated state... state of denial
It does have value, and the lenses have held value well...
The 135/3.5 is an OK lens, the 35/3.5 and the 50/1.4 are good.
I see you mention a 50/4 if that is there it is valuable
adapter, asahi, box, database, extension, gear, lens, lenses, m42, pentax, reviews, takumar, tubes, value
What lenses/gear do you still have from when you started? ChooseAName Pentax SLR Lens Discussion 54 05-27-2013 08:51 AM
Pixoto - does it have any value for serious photography? Darrell Raw Photographic Industry and Professionals 6 07-27-2012 07:57 PM
Just starting, no gear, want to expand, value proposition Biff Troubleshooting and Beginner Help 10 07-15-2009 04:45 PM
Rare Film Gear, need help with determining it's value McD Film SLRs and Compact Film Cameras 24 01-12-2009 08:15 AM
Ist ds upgrade: k10 still a good value? mapov Pentax DSLR Discussion 53 11-20-2008 11:22 PM
All times are GMT -7. The time now is 07:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
