So, having proven that I like Spotmatics, the next step is obviously to brighten things up a little.
I have located online a neat little flash hotshoe adapter that accepts a PC cable and has a top-shoe, viz
Vello Hot Shoe Adapter with PC Socket + Top Shoe - HSA-PSN B&H Insofar as I can tell, this would enable me to mount either of my current flashes (AF200Sa, AF080C ring) on this thing, fit the adapter to the cold-shoe, and then fire the whole kit and caboodle via a PC cable from the X-sync port on the camera.
The only question now is: what sort of cable do I buy for it, i.e. what do the "ends" need to be, esp regarding the size of "end" that plugs into the X-sync port.
I could of course just buy a cheap third-party flash that comes with a PC cable, but this gives me a bit more flexibility in case I want to play with off-camera flash down the road (on any of my film bodies) and it means I don't have three different flashes hanging around.
