11-29-2015, 12:01 AM   #16
JPT
Speaking from previous experiences with testing lenses on this camera, I found that even when the viewfinder showed no vignetting, it could appear quite prominently in the negatives. That's why I tried the zoom, because I wanted to see how far beyond 43mm you had to go to see the in the viewfinder, and the answer was not much.
But having said that, I've just realised I'm talking about a different hood, the MH-RC49, which costs a small fortune to buy seperately. The replacement hood referred to above might be worth a try.
11-29-2015, 12:19 AM   #17
chickentender's Avatar
QuoteOriginally posted by todd Quote
I just put FA43 + LN-RC49 on my ZX-5 again (which is almost at the end of the roll I've been shooting since I got this hood earlier this year and have some actual shots with this combo on the roll...) and put it up to a white monitor screen and see no vignetting through the viewfinder... I haven't seen it in the past either the couple times I've had it on the ZX-5 outdoors in daylight... But I am not disputing what JPT is saying that there may be some on the film.sensor..
Could just be at larger apertures... Curious to find out.
11-29-2015, 12:25 AM   #18
Swift1's Avatar
FWIW, a viewfinder won't really show vignetting.
Years ago I tried using my M100/2.8 hood on my M28/2.8. It works perfectly on APSC digital, so I figured why not try on 135 format film. When that hood was on the 28/2.8 and mounted to my Pentax (huge and bright VF), I couldn't see any vignetting whatsoever, but my images ended up like this,
11-29-2015, 07:27 AM   #19
Why don't you get a DA 40 Limited. It is said to cover the FF. The MZ-3 can drive it. And it may fit your pocket.
11-29-2015, 11:22 AM - 1 Like   #20
6BQ5's Avatar
The FA 43mm is quick to flare and stray light can easily rob images of contrast. I always find the OEM hood to be rather small and lacking. A deeper hood would work better but doesn't look as slick. Then again, who cares what the hood looks like if you are more interested in what the final image looks like? You can use surprisingly deep hoods on APS due to the crop factor. Be sure to verify there is no vignetting by looking at the Live View screen or a sample image.
If you don't want to use a deeper, larger hood then consider using empty filter rings to simply push the current hood out just a little bit more. UV filters can be had for cheap and you can simply knock the glass out if that doesn't bother you.
11-29-2015, 11:40 AM - 1 Like   #21
gofour3's Avatar
This may do the trick, it's the screw-in rubber 49mm OEM hood for the M40/2.8. It collapses to about 10mm and will not cause vignetting on the FA43 shooting film.
Phil.
11-29-2015, 01:19 PM   #22
QuoteOriginally posted by UlrichSchiegg Quote
Well, because I have the 43 and adore it. But more to the point - the DA 40 does not have aperture ring, so it's out.
---------- Post added 11-29-15 at 12:20 PM ----------
QuoteOriginally posted by gofour3 Quote
Phil.
Very cool. I think that could be the ticket. Thanks Phil (The trick here would be finding one that doesn't include an M40/2.8 haha)
---------- Post added 11-29-15 at 01:03 PM ----------
There seems to be a plethora of rather cheap 49mm wide-standard collapsible hoods available on the Bay. Think I'll give one a try.
---------- Post added 11-29-15 at 01:12 PM ----------
Hmmmm.... actually I found an $8 knock-off DA40 style hood and went with that. I'll throw a roll through and report back in a couple weeks or so.
11-29-2015, 03:25 PM   #23
Kozlok's Avatar
QuoteOriginally posted by chickentender Quote
Do tell...where? I'd love to get one!
11-29-2015, 03:54 PM - 1 Like   #24
todd's Avatar
Yes.. Incentive to spend the final shots on the roll with this combo wide open...
Oh now I read this.. We'll see who wins the race.
11-29-2015, 04:02 PM   #25
QuoteOriginally posted by Kozlok Quote
Seller's name on the bay is arphotovideo
---------- Post added 11-29-15 at 03:02 PM ----------
Heheheh - thanks man. You've got a significant headstart with both the hood and roll loaded.
12-22-2015, 04:51 PM   #26
My DA40-style hood arrived. Fits great. Roll loaded in the MX - I've got a few cameras loaded at the moment so will likely take a bit but we'll see. (Now, if only I'd remembered the 30mm pinch cap) :-/
04-12-2016, 11:11 AM - 1 Like   #27
I forgot to update my findings here, namely whether the DA40 style hood had any adverse effects used the FA43 on 35mm film.
Nope. None whatsoever (at none that I've noticed as of yet - 2 rolls in) ... So that in fact I completely forgot to update this thread.
At any rate, for any interested, that style hood certainly takes away a bit of bulk from OEM hood on the lovely compact 43mm.
This was shot with with the FA43 and MZ-S on SvemaColor125....
On the MZ-3 it is a very diminutive and lovely combo. Show with MX and A50/1.4 for scale.
04-12-2016, 12:48 PM - 1 Like   #28
todd's Avatar
Nice work detective! I on the other hand should be terminated... Well at least finished the roll but didn't get it developed yet... My only detective work now will be figuring out which shots were taken with FA43 when I finally do get it developed..
04-12-2016, 02:07 PM   #29
It's true, you've had *ample* time and a headstart to boot! You're fired!
Nah, dev that stuff and get'm up.
04-13-2016, 01:56 AM   #30
Lots of my frames are shot with single coated lenses (some with cleaning marks,) single coated filters, and lens hoods.
Cause flare into shadows and highlight artifice gives my mono prints a period look, and can preflash the AgX crystals.
It will/would also pastel shadows and mid tones in colour.
Filters and hoods protect during drop tests and sea gull PGM.
PGM - precision guided munition
49mm, camera, comparison, contrast, da, filter, flare, hood, hoods, kit, leica, lens, lens cap, lot, m40/2.8, mine, phil, pm, post, protection, replacement, roll, rubber, sun, thanks, trick, uv filter
FA43 hood alternatives todd Pentax SLR Lens Discussion 10 12-07-2014 03:17 PM
DA 21mm Lens Hood Necessary? K206 Pentax SLR Lens Discussion 13 03-07-2011 10:19 PM
Is a filter necessary for the DFA100mm WR? ohyouloveme Pentax SLR Lens Discussion 10 11-25-2010 03:20 PM
Lens hood - when is it necessary? esman7 Troubleshooting and Beginner Help 26 09-11-2009 07:03 PM
Lens hood like the FA43 -- where to find? rparmar Pentax SLR Lens Discussion 13 04-10-2009 03:08 AM
All times are GMT -7. The time now is 10:42 AM. | See also: NikonForums.com, part of our network of photo forums!
