Originally posted by LesDMess The Nikon F3 needs the T mode because among all settings available on it's shutter speed dial, the ONLY mechanical setting is 'T' (Time exposure). It doesn't draw battery power from the camera and thus it is a perfect setting for extended time exposure photography.
True....unless you use the mechanical shutter release on the front of the camera to trigger a 1/90" sans battery. My Pentax 645 can also be triggered without a battery and can advance the film manually with the same make-shift trigger. It has saved me on more than one occasion when I had power issues. On the 645, however, you can't use it manually (no power) with bulb. And with my Nikon F3, you still need power to trigger T, but as stated previously, it doesn't draw power to keep the shutter curtain open. Changing the shutter speed dial off of T closes the second or rear shutter curtain.
---------- Post added 12-16-15 at 11:43 PM ----------
Originally posted by lmd91343 Here is the little bit I know about Canons:
The "Flex R 2000", marketed '60 - '62 was the last SLR to have a T speed.
The "7s" and the "7sZ", manufactured until the mid '70s, marketed '65 - '80, was the last Canon RF. It had a T speed. One of my Canon "7s" cameras has a date code of '72, if memory serves me.
You mean the last Canon SLR to have the T mode? My Nikon F3HP from 1986 has a T mode. And I believe there were a few Pentax models long after '62 that also had the T mode.
