01-14-2016, 11:49 PM   #1
What type of metal does the ME Super use?
I'm curious as to what the body and components are. Are they steel, aluminum, magnesium, or something else?
thanks,
Davide
01-15-2016, 05:43 AM   #2
D1N0's Avatar
I'd think Aluminum body and steel parts?
01-15-2016, 07:20 AM   #3
THoog's Avatar
Mostly brass and steel. The top plate is plated (or painted, for the black version) brass. Hence the term 'brassing' when the corners get worn. The mount plate is also plated brass. I think the back door is steel. The workings are a mixture of steel, brass, plastic...
01-15-2016, 08:30 AM   #4
QuoteOriginally posted by THoog Quote
Maybe they used different materials in the production life time.
The ME Super here, taken apart for parts:
top cover is plastic
Bottom plate is aluminium
body is die cast aluminium ( or similar alloy)
Front leatherette covers are plastic
rear door is steel
K mount is aluminium
A lot of the small mech parts are pressed steel.
The hotshoe claws are aluminium, and the hotshoe plate looks like stainless steel.
01-15-2016, 05:48 PM   #5
The mount is chrome plated brass and the bottom cover is chrome plated brass.
01-15-2016, 10:32 PM   #6
Thanks for the replies, everyone. Sounds like it's brass or aluminum.
01-16-2016, 05:04 AM   #7
D1N0's Avatar
Just file a bit off, if it's yellow it's brass, and if white aluminum
01-16-2016, 09:20 AM   #8
QuoteOriginally posted by D1N0 Quote
Thanks. My ME Super already has enough scratches that I didnt need to add any. The scratch fissures are silvery, so I guess it is aluminum. I used to keep the old 50mm 1.4 Takumark and 35mm f2 screw mount on it via screw mount adapter. I wonder if I was inadvertently running the same experiment the Curies did when they induced radiation in aluminum.
01-18-2016, 07:12 PM   #9
QuoteOriginally posted by davide Quote
From what I understand, M-series body top and bottom covers would be either chromed brass or plastic. The MX is brass and it appears that the ME Super may be either. I found online photos with obvious yellow brassing and others without.
type of metal
Pentax me super film type kaitlynn Visitors' Center 2 08-10-2015 01:32 PM
Just bought a Pentax ME Super + 2 lenses What kind of settings could i use each in? gurpswu Troubleshooting and Beginner Help 26 08-19-2011 05:42 PM
Ordering from BHphotovideo.com to australia. What type of shipping do you use? TheTenaciousOne General Talk 8 04-06-2010 06:18 PM
What is the battery type for ME Super? HermanLee Pentax Film SLR Discussion 7 12-10-2009 01:40 PM
what type of metering does the K10... slip Pentax SLR Lens Discussion 3 04-12-2007 09:05 AM
All times are GMT -7. The time now is 03:14 AM. | See also: NikonForums.com, part of our network of photo forums!
