I own a Pentax K1000 film SLR camera. Earlier today I loaded film into it to shoot. I had turned the lever and the rewind crank was turning the canister as it should. However, as soon as I closed the camera and kept advancing, the first one or two cranks had almost too much resistance and I could hear cracking happening in the camera. Then it went back to normal and the film advanced normally through all my shots. After I shot the roll, and began to rewind the film back into the canister: but again there was a lot of resistance and cracking sounds. I think part of the problem might have been that when I rewound the film, I did not press the auto-winder button at the bottom of the model. Once I opened up the back of the camera, the film was ripped from the canister and still wrapped around the take up spool.
Does this issue sound like something that happened because i didn't press the auto-winder button, or could there be something else wrong with the camera/should I get the camera or a specific part replaced?
Thank you all! Let me know if a picture would be valuable.
