02-24-2016, 08:04 PM   #1
Pentax K1000 Version
I recently received a K1000 as a part of lot of equipment and the faux leather was peeling. I ordered a replacement and to my surprise it doesn't fit (the leather is fine). There's a metal circle of some sort to the left of the mount. No markings of any sort. So for those who are knowledgeable, what is this? Name:  ImageUploadedByTapatalk1456369336.911901.jpg
Size:  62.8 KBName:  ImageUploadedByTapatalk1456369461.694668.jpg
02-25-2016, 12:05 AM   #2
Somebody made a "ruggedized" version of a few different cameras. It involved replacing the standard leather with a slightly thicker leather with a different pattern and charging more for the camera. Maybe that disc is from that scenario. The disc has no purpose and you can remove it.
02-25-2016, 05:34 AM   #3
Those little metal discs are quite common and usually cover an access hole in the body, can't quite imagine why there would be a hole there though. It's only self adhesive so prise it off, if there is a hole then stick it back on, you can't cause any damage.
The K1000 was made in various countries and as far as I know these were not officialy viewed as different versions. There are various different markings i.e. Made in Japan or Made in Hong Kong etc.
Usually the early ones had a metal top plate with the Asahi Logo stamped into it the later plastic ones didn't have the logo but as far as I know the bodies were all the same size so I would expect the leather to be interchangeable, but I could be wrong.
02-27-2016, 10:59 PM   #4
Did you get the leather from cameraleather.com? I've had mixed results with their products - nice quality but hit-and-miss regarding proper fit.
02-28-2016, 01:40 AM   #5
QuoteOriginally posted by Focalplane Quote
I did. I'm still cleaning off the old glue but the pieces look like a match to the old ones (but also look tiny, if that makes sense)
k1000, leather, pentax k1000, sort
Pentax K1000 anniversary - need all Pentaxian help an can get MilkaSchokoHase87 Pentax Film SLR Discussion 9 12-02-2015 04:22 PM
No K1000 SE Japan version? minitw Pentax Film SLR Discussion 1 10-28-2012 09:01 PM
M42 Super Takumar 135/3.5 version 1 vs. version 2 raymeedc Pentax SLR Lens Discussion 4 12-24-2009 11:49 AM
K1000 how to tell Japan made version? manteiv Pentax Film SLR Discussion 5 12-09-2009 01:56 PM
K1000 Version wlank Pentax Film SLR Discussion 7 07-31-2008 05:11 AM
All times are GMT -7. The time now is 12:52 PM. | See also: NikonForums.com, part of our network of photo forums!
