Originally posted by Basie Hi
If you advance the film with the lever the rewind knob should turn showing that that the canister's axle is revolving as the film is rolled out. You should also see it quite clearly when you load the film that the film advance lever advance the film with the sprockets engaged
If you have a 24 or 36 shot film and you keep on going after that many shots, you might have a problem....
Cheers and enjoy
Ensure the film moves with the sprockets by taking up the usual slack in the film canister and rotating the rewind * gently * clockwise so your unexposed film is firmly held in place.
As you move to cock the shutter and advance the film, check the rewind knob is moving anti-clockwise at the same time.
This is your main cue for checking the film is being wound without opening the back of the camera.
