Originally posted by LesDMess However, it is not a form of TTL flash so it is a curious concept and I wonder how it works.
As I stated above, it's like a thyristor flash but with the thyristor sensor on the camera body and (I suppose) with extra circuitry on what might loosely be called the X-sync bus, to enable the sensor to cut the flash off at the appropriate instant. This theoretically goes one better than having the thyristor sensor on the flash, because you can put the flash anywhere within its brightness and angle coverage and the exposure will still be correct at the camera.
If you try this with a normal flash-mounted regulating thyristor sensor (and I have), quite often you will NOT get a fully exposed picture because the flash is working on the assumption that it is mounted on the camera, roughly equidistant from the film/sensor plane, when all too often it is not.
