Originally posted by Johnny Rod The foam bumper doesn't look great, you can just get your fingernail under the edge of the mirror and release it from its sticky grip. The foam turns to gunge as mentioned, I replace mine with strips cut from a sheet of closed-cell black self-adhesive foam from a craft shop, it's 2-3mm thick (can't remember but it matches the Pentax foam thickness well)
Black Self-Adhesive A4 Foam Sheet | Hobbycraft Confirmed.
Easy.
Favorite Classics / Jon Goodman's Seal Replacement Instructions
You need to do it soon rather than later as the foam eats paint and can damage mirrors!
I just use mouse mat foam, scissors, double sided pressure sensitive tape.
Removing foam needs a can of zippo, wood meat skewer and qtips.
And a lotta time.
You may need to remove foam under top plate too before it eats the prism.
