Originally posted by lowlandspentax Thank you Xmas for that interesting and helpfull link!
No one can point me to advice to clean the outside of the cam?
I searched on the forum but did not find a topic/advice on this.
It did not belong to a pentaxlover, and is quite greasy, dusty and stained.
A tiny bit of rust below the backside door and black paint shaved off the metal base on multiple spots.
I would be intended to use Q-tips and lighter fuel (as a solvent), but do not know this (the fuel) will harm.
Will some repainting of the body be durable?
To Jon's site: he is offering a pre-cut pack for the Pentax ME, am i right this will not fit to my MG (because the bodies differ)?
I cannot compare to a ME as i do not have one.
Thank you,
lowlandspentax
The degenerate foam may have damaged the paint, a wooden scraper is needed on softened foam, it is well difficult to remove even with zippo swabs of cotton waste.
Zippo is normally safe on paint but try and keep it out of innards or on optics.
You can use zippo on chrome but not on the plastic or leatherette covering it can upset the adhesive holding the cover on.
I just clean the interior of the camera as dust can get on film. Don't often clean optics. My SP has right bad rust and pits... The colours of the wind on and meter switch barely detectable, Mirror coating lifting but still does nice exposures. And is easy to use...
I only bought it for its lens, but it is nicer camera to hand than a K1000!
Don't bother replacing covers myself, nor repainting bare metal.
If there is foam on the prism under the top plate it can damage the prism.
Try a film in case you have a shutter or other problem after refoam, a trip to repair person is frequently more expensive than a second body.
I just cut foam from a mouse mat and use double sided pressure sensitive tape you only need scissors or a craft knife and straight edge. Real easy!
