04-26-2016, 09:23 AM   #1
Could light leaks lead to washed out daylight photos?
Mine definitely needs mirror bumper replacement. I figured it out with the spot of the light leak, but can foggy-sort of, washed out images be caused by light leaks? Fujicolor C200, Pentax ME SE, smc-m 1.7 50mm
04-26-2016, 09:47 AM - 1 Like   #2
Look at the negatives with a strong light behind.
Rebates and interframe gaps need to be uniform apart from frame number and film Id.
Easier if you use mono film.
If they are not uniform you have a light leak somewhere.
04-26-2016, 10:39 AM - 1 Like   #3
Not a Number's Avatar
Some light leakage from the viewfinder can happen even with a good mirror bumper. That's why an eyepiece cover is recommended for long exposures or any time you are shooting without your eye over the viewfinder.
But yes, this could lead to metering errors or the negatives getting flashed.
The most common area for light leakage is at the hinge. In this case the area outside the normal frame, e.g. sprockets will be exposed too. It's best to change all the light seals and mirror bumper at the same time. Even if some seals are marginal they will deteriorate soon enough.
Posting scans of your negatives may be helpful.
04-26-2016, 11:09 PM   #4
thank you! I'll take a look at my negatives soon.
04-27-2016, 09:42 AM   #5
QuoteOriginally posted by pentytaxy Quote
Favorite Classics / Jon Goodman's Seal Replacement Instructions
The foam can let light leak, get into shutter, stick to mirror and ground glass screen.
The kits Jon sells are as good as his instructions.
But I use mouse mat, double sided pressure sensitive tape, scissors, wood meat skew, qtips and zippo.
It is hard on the mouse.
04-27-2016, 06:07 PM   #6
Eyewanders's Avatar
QuoteOriginally posted by Xmas Quote
I've used one or two of his kits. They are really quite cheap and perfectly put together. Seconded.
04-28-2016, 05:35 AM - 1 Like   #7
I use a lens hood on my /1.7, and it is gin clear glass.
leaks, light, light leaks
Landscape Washed out photos (Fujicolor C200) pentytaxy Photo Critique 3 04-20-2016 09:58 PM
Pentax 6x7 light leaks Pedrosa Troubleshooting and Beginner Help 9 08-03-2014 03:03 PM
What to use for testing light leaks? 6BQ5 Pentax Film SLR Discussion 3 02-03-2014 04:32 PM
Washed out over exposed photos ajaxmgr Pentax K-5 24 08-22-2012 12:55 AM
Your Photos -- From Washed Out To Punchy rparmar Photographic Technique 3 06-21-2008 05:21 PM
All times are GMT -7. The time now is 04:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
