06-13-2016, 12:52 PM   #16
glee46's Avatar
QuoteOriginally posted by dcshooter Quote
Seriously, it's not one piece of metal. The picture you showed with the screw hole is where the catch spring was connected:
You can see the placement of the spring on this image. You can also see the cutouts on the left and right that are clearly visible on yours.
Here's an image of two adapters, one with the spring on, and one with it off:
(pay no attention to the filing instructions - they are part of the tutorial I lifted this image from)
Trust me, it's one solid piece Look at the same type of mount in Post #10. It's a M42 Male Thread which goes into a M42 adapter on the camera. I'm making a video to show everyone what I am talking about & to show that this is one solid piece.
---------- Post added 06-13-16 at 01:17 PM ----------
I need to apologize to everyone here. You were right. It was an adapter which using a pair of pliers I was able to get off an attach an M42 adapter. I've played around with these things for years & I got tunnel vision. I was so sure about something that I lost sight of what was right before me. Of course, I feel like an idiot, but very grateful to those here, & to the seller who has been outstanding in helping me see.
06-13-2016, 01:24 PM   #17
BigMackCam's Avatar
QuoteOriginally posted by glee46 Quote
No apology needed, I'm just glad for you (and for my sanity) that you figured it out! I looked at post #10 and could see what you meant, but in post #11 you can see that the K-mount piece isn't the same lump of metal as the M42 bit. I was just about to reply when I read your last post
06-13-2016, 02:05 PM   #18
Not a Number's Avatar
Not a problem. It just goes to show that Pentax's machining tolerances are pretty fine so it could look like one piece. I hope you didn't chew up the M42 adapter too much with the pliers, especially if it is a genuine Pentax adapter. Maybe the seller has the screw and clip?
06-13-2016, 02:45 PM   #19
glee46's Avatar
And Now the Icing on the Cake
I'm happy to say I have full frame coverage using my K-1. I'll take some shots of the rig and show it off.
I'm using the HDMI out to one of my monitors so that I'm able to get better focus. Wow! I'm really jazzed to get this going. Next comes developing my own film.
I'm using at this point a Pentax 55mm f.2 and a Vivitar 50mm f/1.8 M42. I wonder if a Pentax 50mm f/4 Macro M42 would work even better on it. I don't have one, but I'm thinking about purchasing one.
06-13-2016, 02:51 PM   #20
So the rear standard of the bellows clears the body of the K-1? No "scratch" problem as with some Sigma lenses?
Let's see some photos of bellows attached to the K-1
06-13-2016, 04:28 PM   #21
glee46's Avatar
We Have Pictures
I have added a thin K-mount extension tube on the front of the camera. When you look at the pictures you will see it. I still get full frame coverage with it. Here's a link to about 10 shots of the setup: https://www.flickr.com/photos/one_thing/albums/72157668816092560
Here's one of the shots from the album. I'll do a more precise little article soon as well.
06-13-2016, 05:15 PM   #22
MarkJerling's Avatar
Trust me, you don't want the screw and clip. It can be hell to remove the adapter from your camera. Which is why most people discard the clip and screw.
06-13-2016, 05:28 PM   #23
QuoteOriginally posted by MarkJerling Quote
Really? I've been using the genuine adapter for years with the clip. Never a problem. I'm not the only one.
Will it fit without the extension tube?
06-13-2016, 06:24 PM   #24
glee46's Avatar
No, you need some room for it to fit. I would think that you could purchase a cheap set of K-mount extension tubes for under $10. The one's I have can go for as high as $150 which is stupid unless you're a collector.
Do you know anything about using a 50mm f/4 Macro M42 with the type of setup I'm using? My 55mm f/2 M42 is fine, but I want the best focus that I can get from my prints.
06-13-2016, 08:04 PM   #25
Everyone I know, who use the adapter, removes the clip and screw. Of course, you may not be the only one who does not! The topic comes up for discussion from time to time in these forums.
06-13-2016, 08:36 PM   #26
Again I agree with Not a Number. Never remove the clip from a genuine undamaged Pentax M42 adapter. But always remove the clip from non genuine Pentax adapters. The non genuine adapters just are not built to the same tolerances and sooner or later cause problems. I speak from experience.
06-13-2016, 09:27 PM   #27
glee46's Avatar
QuoteOriginally posted by beachboy2 Quote
Genuine is the key word. I found out the hard way myself, which I think many have done so as well. I have 1 Genuine and 4 Fotodiox adapters.
I got my Fotodiox adapter 1st. I had to use a Dremel tool to cut it off my Pentax 135mm f/2.5. The Genuine has never caused me a problem. YMMV.
---------- Post added 06-13-16 at 09:44 PM ----------
When I shot my 1st roll of film a few weeks back, I took it to a professional developer. It cost me @ $12 for each roll, and they uploaded them the next day. I was happy to see that they all turned out, but they were not the greatest pictures on my part. Some out of focus, over/under exposure, but they were super grainy looking. Did some LR/PS helped but all they sent was jpegs. With RAW/DNG, at least I have something to work with to make them better.
Anyway, here are two pictures. The 1st one was what I had developed and sent to me via email. The 2nd was after I drove over there and got the negatives. I scanned them using my FF K-1. There is a major difference in my eyes. My model would kill me for putting these up as she was not having a good hair day & didn't come to work to shoot that day.
So, what say you between the two?
Pro Developer My K-1
06-13-2016, 11:03 PM   #28
chickentender's Avatar
To my eye the DSLR scan is quite soft (and I'm assuming that's just a straight export from the raw unprocessed image) and as if the negative was not flat - seems to be some distortion. Which one matches the contrast and details of your negative under a loupe? That's what I'd look at.
What scanner did your lap use and what resolution is the emailed file? It looks to have a large amount of USM applied and obviously more contrast. Those are two very, very different images to me.
06-14-2016, 05:33 AM   #29
Marketplace Reseller
dcshooter's Avatar
Looks like you are out of focus on your shot, partially stemming from the unevenness of the slide surface. Check out the top of the girl's head and left arm, as they are way more out of focus than her face is is. Try refocusing and stopping down your lens more to get more DOF. Rear lighting the slide copier with a flash might help, too.
Re: chickentender's comments on Contrast, that is something tha can be adjusted for in Post if you are shooting RAW.
---------- Post added 06-14-16 at 05:39 AM ----------
Also, taking a look at the pics of your rig, it appears you are using a standard 55mm f/2 Takumar? If so, you'll probably get much better results around the edges with a flat field dedicated macro lens.
06-14-2016, 06:13 AM   #30
I have the Super-Multi-Coated 50mm f/4 macro. Definitely can be used with that setup. The problem is slides tend to curve in the mounts - the acetate side (non-emulsion) tends to bulge out - a bit of pincushion effect. That's why the lenses on slide projectors (except pro models) have a slightly curved field. So sometimes a normal lens may work better. You can use glass slide mount to flatten the slide but then you get Newton rings (a sort of Moire type pattern). Sometimes shooting from the emulsion side of the slide helps. Just remember to flip the image in post processing. Relative humidity and heat can effect the curvature. When using a slide projector you can see the focus "pop" as the curvature of the film changes from the heat of the projector lamp.
A flash as the light source could give you more light for a greater DOF.
Have you tried Pixel Shift resolution (unrelated to slide curvature)?
Just as I suspected. The standard on the K-mount bellows is even larger so a small extension tube would be in order. I can always use my Minolta Auto Bellows III with slide copier since I need to use a K-mount to Minolta SR (MD) adapter - about 10mm of extension.
With the M42 bellows I suppose one could use M42 extension tubes. The original Asahi auto tubes can be had for under $30 with the case if you wait long enough on eBay..
Have you noticed any "play" in the M42 to K-mount adapter? If found this to be a problem using the Auto Bellows on my K10D and I had to be careful not to "rotate" the camera which makes focus stacking or time-lapse sequences more difficult. I think a flanged adapter as I linked above would solve that problem
1st, adapter, adapters, camera, clip, day, developer, error, film, focus, fotodiox, image, k-1, lens, m42, macro, mount, pentax, photography, picture, pictures, piece, post, roll, screw, shift, slide, surface, unit
Nature 10 hours on a kayak and this is all I've got to show for it... Auzzie-Phoenix Post Your Photos! 4 06-24-2015 10:07 AM
Dang! I've got taxed for a lens I got from Italy pcarfan General Talk 5 05-14-2010 07:48 AM
I've got a new blog! heatherslightbox General Talk 5 04-21-2009 05:44 PM
Juhu, I've got a Pentax perejnar Welcomes and Introductions 2 01-26-2009 01:40 PM
I've got a Seagull richard64 Pentax SLR Lens Discussion 2 08-05-2008 05:27 PM
All times are GMT -7. The time now is 12:33 PM. | See also: NikonForums.com, part of our network of photo forums!
