Originally posted by JDphoto So I am going to start a film photography class in a couple of weeks and I am so excited. My dad gave me his old Pentax k1000. So I was playing around with it and realized that I can't change the ASA. When I pull up on the ring it gets stuck and won't move. Has anyone else had this problem and if so how did you fix it?
Remember that the K1000 is completely mechanical, so if the asa dial won't move it will only affect the light meter, not the camera itself. If you can't get it fixed straight away just take the battery out, ignore the light meter and shoot away!
There's a few other ways of metering (a lot of older cameras don't even have internal light meters...):
- If you're carrying a digital camera use that to measure exposure.
- Use an external light meter (if you're doing a film photography class there will probably be one you can borrow)
- Use a light meter app on your smart phone (there's lots - 'Pocket Light Meter' is good for iOS)
Keep in mind that negative film isn't as sensitive to exact exposure as digital, so it doesn't matter if you're off a little. It's also a great learning process to set exposure without an internal meter
