06-27-2016, 11:17 PM   #1
Delta 3200 meter/develop question
Last night I shot a roll of Delta 3200 at my friends wedding with my LX. I only realized that's the meter wasn't on 3200 but the tick right before it when I unloaded the film. Should I have the lab develop as regular or something else?
06-28-2016, 12:05 AM   #2
No treat it as normal.
You should use it at 1000 ISO for normal prints, unless you want the black shadow signature.
If you were wet printing 3200 ISO is hard work.
06-28-2016, 06:22 AM   #3
On the mark just before it shouldn't make enough difference to warrant changing the development, so don't worry
06-28-2016, 09:33 AM   #4
mattt's Avatar
If you read up in Delta 3200, the verdict is it is a sub1600 speed film that pushes well.
The slightly slower (1/3 stop from "box speed") you might have exposed to won't have much an effect on the development.
06-28-2016, 01:01 PM   #5
chickentender's Avatar
Yup - all the above. You're fine. Delta has a silly amount of latitude.
06-28-2016, 06:19 PM   #6
Having actually measured the real shutter speeds on a few of my older cameras, it's rare for them to be within 1/3 of a stop of the stated speed anyway - definitely within the margin of error for B&W film
08-05-2016, 10:58 AM   #7
bobbotron's Avatar
QuoteOriginally posted by chickentender Quote
My experience with Delta 3200 is the opposite of that! :P
08-05-2016, 11:06 AM   #8
QuoteOriginally posted by bobbotron Quote
FYI, the Delta 3200 Data Sheet gives development times for Exposure Indexes of ISO 400 - 6400 for a bunch of developers.
I've shot and developed it successfully at EI 400, EI 800 and EI 3200. I'm convinced it has a wide exposure range. Similarly with 400TMY. I shoot it at EI 50, 100, 400 and 800 too.
Delta @ EI 3200
@ EI 800
@ EI 400
Another at EI 400.
08-05-2016, 11:08 AM   #9
I've gotten the photos back. They came out perfect. Some issues with shadows in people's eyes but way better than the tri X at 1600 I pushed that night.
08-05-2016, 11:34 AM   #10
Size:  330.5 KBName:  Image1470422061.694962.jpg
Grainy but that was to be expected. LX, K50 1.2 for both.
08-05-2016, 12:04 PM   #11
bobbotron's Avatar
Sorry, wide exposure range... but I find you reeeeeally need to get the shot correctly exposed, and underexpose == a lot of loss of detail.
Delta @ EI 3200
@ EI 800
@ EI 400
Another at EI 400.
08-05-2016, 12:13 PM   #12
In the wet print only days, development times varied for the same film/developer combos up to 15-20% ( which is a lot) depending if you had a diffusion or condenser enlarger. Back then you needed to target a contrast index of the paper/enlarger combo.
Today, with scanning, you don't have to do that. The scanner and image editor contrast curve adjustment gives you a wider tolerance range for your development time. That is, your development time can be off easily up to 15% from normal and you'd not even notice the difference in the results with a good scanner and adjusting the contrast curve yourself. In other words, being a 1/3 or even a 1/2 stop off in exposure index is nothing. People get this 1/3 -stop exposure tolerance ( or even 1/2 stop) from positive film, I feel. BW negative film is a different animal with today's figital workflow. YMMV.
EDIT: Note all those shots were without a light meter (except the dog shot) and all rounded off to full-stop increments.
08-05-2016, 12:59 PM   #13
bobbotron's Avatar
I found, deving it with DD-X, if underexposed it trends to totally clear negative. It gives really neat results... but in low light situations there's no shadow detail to bring up if you've slightly underexposed.
This is 3200, and one of my fav photos of these two dogs.
Same roll, I guess slightly under exposed, and there was not a lot of silver on the negative to work with.
08-05-2016, 01:19 PM   #14
...but in low light situations there's no shadow detail to bring up if you've slightly
Nice pictures.
08-05-2016, 06:26 PM   #15
QuoteOriginally posted by kxjiru Quote
If you like shadows 800 ISO is it.
If you were on graded paper you were careful with lighting and development.
A outdoor cine team had a vehicle for reflectors they printed by contact!
delta, delta 3200 meter/develop
Issues developing Delta 3200 bobbotron Pentax Film SLR Discussion 18 01-09-2016 12:03 PM
TriX 400 pushed or Delta 3200? dugrant153 Film Processing, Scanning, and Darkroom 12 05-20-2011 06:43 PM
Pentax 645 + Ilford Delta 3200 @ 1600 = awesomeness dugrant153 Pentax Medium Format 26 04-11-2011 03:54 PM
Ilford Delta 3200 - shoot at 800-1600, develop at 1600? dugrant153 Film Processing, Scanning, and Darkroom 15 11-08-2010 02:27 AM
Amsterdam, Delta 3200, M6-60 Erasmo Post Your Photos! 4 10-25-2008 05:30 PM
All times are GMT -7. The time now is 03:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
