07-29-2016, 04:48 PM   #16
QuoteOriginally posted by elho_cid Quote
The main difference is panchromatic vs silver halide. That's the choice you need to make.
I don't believe the two are mutually exclusive. Were you thinking chromogenic as opposed to traditional silver-based image?
07-29-2016, 05:59 PM   #17
QuoteOriginally posted by John Elger Quote
Hey,
I shoot an analog BW from time to time and I would like to ask you what difference can I expect from different film manufactures?
If that were not enough, you will also have to consider the effect of the great variety of developers have on these films. What a great journey to look forward to . . .
08-16-2016, 08:09 AM   #18
QuoteOriginally posted by LaHo Quote
I see that you live in Prague. Then Fomapan would be a no-brainer for me. Foma films are much cheaper than Ilford and Kodak when you live in Czechia and can yield some very pleasant results. I have had a few films with production faults (scratches) in them, but when taking pictures with an old Mamiya, it somehow fits the look. At other times such scratches can be a nuiscance. Still - you can shoot much more if you stick with Foma films. BTW, Bé Foto, Janovského 5 is cheaper than Skoda Foto.
I like the old-fashioned look of Foma films, here Fomapan 200 Creative:
Camera: Mamiya C330 Professional
Lens: Mamiya-Sekor 65mm F3.5
Exposure: 1/500 @ F5.6 (Y2 filter and rubber lens hood)
Film: Fomapan 200 Creative dev. in Compard R09 Spezial
I'M from Czechia ans Fotoskoda is rally not a cheap strore.
I use Fomapan 135 200 or 100 and stock Foma developer, fixer with Pentax MX and I might have some scratches but it might be my messy procesing.
I haven't scanned a lot but here are Foma samples https://www.flickr.com/photos/82601786@N03/albums/72157653558672198
08-16-2016, 10:45 AM   #19
QuoteOriginally posted by AldaCZ Quote
I've used Fomapan 100 & 400 135, bulk and 120 from '05 without any problems and I need to use a film squeegee as I live between to chalk streams the furthest 5km.
Temper better than 1C and water stop.
08-17-2016, 12:01 PM   #20
No one has mentioned cubic grain vs tabular grain BW films. You can expect difference there both in look and feel and how fine the grain is for an equivalent box speed rating. That was a big deal and generated much controversy, mostly among sheet film users, when the tabular grain was introduced if I recall correctly.
08-18-2016, 04:43 AM   #21
Confirmed if you want fine
Panf, Delta 100, Tmax100 last two tabular
If you want coarse
HP5+, Tx, Foma400
All three cubical though the Tx is finer grain
08-18-2016, 05:54 AM   #22
QuoteOriginally posted by Xmas Quote
If you want coarse
HP5+, Tx, Foma400
Yes, and if you want course, develop your film in Rodinal
08-18-2016, 12:00 PM   #23
Confirmed Fomapan 400 is nice in Rodinal.
08-24-2016, 05:48 PM   #24
PGillin's Avatar
Well, as has been said it's a good idea to stick mainly to one film (or perhaps two, one faster and one slower) until you know it well, then begin experimenting.
The foma films in ISO 100 and 200 (especially the 200) I've found to be quite good, and I like them a lot. However, in the 400+ range Ilford is the best choice. Tri-X is already grainy at 400 and is not useful pushed to 1600 or above. I shot 100's of feet of it when I started with film, and was usually displeased with the results in low light.
I changed then to Kentmere 400 to save some money, found it to be better at 800 and 1600 ISO, although tri-x is nicer at 400.
The real winner, though, is Ilford delta 400. Nice, fine grain, good tones, and strong contrast.
So, perhaps you would find Foma 200 to be a good daylight film and Ilford delta to be a good product for low-light.
Hopefully that helps, there are already many good answers here and taken together they should be very useful.
08-25-2016, 03:21 AM   #25
Jonathan Mac's Avatar
I like Tri-X at 1600, though I admit it's the only film I've tried at that speed. HP5+ (of which I understand Kentmere 400 is a cheaper version) is already too grainy and low contrast at 400.
08-25-2016, 05:08 AM   #26
aurele's Avatar
Hey,
I shoot an analog BW from time to time and I would like to ask you what difference can I expect from different film manufactures? I'm used to shoot Ilford film but my local camera store offers there three brands (Ilford, FOMAPAN and Kodak). Are there any differences? Talking about the same ISO.
Thank you very much.
Best regards,
Jan Elger
If you scan your film, the "base" on which the sensitive layer is put will have some influence :
- The ilford film remain flat, and don't curl, which is great when you scan.
- the Kodak tend to curl.
- I don't know the foma, never tried.
About the iso : read the spec sheets of film, you can find some details like "400 iso film, better shot @320 for contrast" for example.
So far, with the shop processing (in Paris, we do have a very good photographic shop, that do process really well film), between the kodak and the ilford film, the best @1600 and 3200 remain Delta 400. It's less contrasty and offer more latitude when scanning. The HP5 and FP4 when push, are like the kodak : very contrasty, grain quite visible (but this contribute to a sens of sharpness and detail, IMO).
As some said, the best thing to do, is try them all You'll notice some differences, and only by seeing them yo will be able to decide what you like. You won't know what you may like, until you see it.
11-25-2016, 08:36 AM   #27
John Elger's Avatar
Ok thank you all for a lot of great and helpful advice I didn't expect so much response. I finished shooting my whole trip on Kodak Tri-X and I'm more or less satisfied by the results. Nonetheless I'd like to try shooting some HP5 in the future. But now with such erudite debaters as are here on pentaxforums I'd like to ask a few more questions.
1. What does it mean when film curls while scanned?
2. What reasonably priced film negative scanner would you recomend for home purchase?
3. What developing chemicals would you recomend? (I still use Kodak tri-x but wanting to try HP5+ and delta 100.
4. I'm planning to shoot project with working title "straight from 1930's 40's" and I would like to ask if there's any type of film on the market that has not changed since than. I've discovered that for example tri-x was introduced in 1954.
11-25-2016, 09:32 AM   #28
Ilford FP4 dates back to 1935 acording to wiki.
Here is one taken in FP4 in 1980 with the ME Super and the -M 1:2 50mm
https://app.box.com/s/6m616czwq1ckp1gwnxdx3w7rctmr2acy
Welcome to ILFORD PHOTO
11-25-2016, 09:56 AM   #29
gofour3's Avatar
Rollei and Adox make some interesting "experimental" b&w films that would be good for you project.
Phil.
11-25-2016, 05:06 PM   #30
ChrisPlatt's Avatar
Ilford FP4 was likely reformulated when it became FP4+ (Plus) in 1990.
Kodak Tri-X has been reformulated numerous times since it was introduced.
Some BW films from smaller EU manufacturers are closer to older formulas.
There are also ways to achieve a more classic look with modern materials.
Chris
film, ilford, time
Kodak slide films kxjiru Pentax Film SLR Discussion 10 11-07-2014 02:24 PM
Kodak Discontinues slide films :( twitch Pentax Film SLR Discussion 14 04-03-2012 02:20 PM
Bad news for MF: Kodak discontinues colour reversal films veraikon Pentax Medium Format 12 03-09-2012 10:39 AM
Kodak TMax 400 or Ilford XP 2 Super mccarvindh Pentax Medium Format 13 02-07-2012 05:36 PM
MX & Ilford shots (1280x817), discuss: T-grain/delta films. CSoars Pentax Film SLR Discussion 6 12-10-2008 01:26 AM
All times are GMT -7. The time now is 06:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
