I'd say be wary of the recommended ISO - drop it down a third or half of a stop to be sure, negative films love overexposure. Some manufacturers are a bit optimistic about their product. Use a common developer: D76 is the gold standard and it won't spring any surprises on you if you stick to standard developing times, which are quite manageable.
Different manufacturers films have different tonescales - the developer you use can impact this drastically.
Originally posted by derelict Delta 100 and TMax 100 and will tell you that TMax is more flexible but Delta is sharper.
Delta isn't sharper, you're mistaking grain for detail. Delta 100 has higher RMS granularity is than T-max - but developer used has a
massive effect upon this, T-Max 100 Exposed @ ISO 50 in Pyrocat is
amazing.
Originally posted by elho_cid panchromatic vs silver halide. That's the choice you need to make.
What? if you undersood what panchromatic means, you would know all the things that are wrong with the above statement.
Originally posted by drmoss_ca I think you mean chromogenic vs silver halide
That is more like it. Chromogenic films is dye based - there is no grain, but dye clouds; unlike classic silver halide films with silver grains. Chromogenic films can handle similar degrees of abuse that negative B&W films can handle - but they are tedious to develop as instead of classic B&W processing you have to do C-41....I have heard you can use B&W developers on chromogenic films. I hear the results are...
interesting.
Originally posted by tuco develop your film in Rodinal
Be warned, developing ISO400 films is acquired taste. If care is taken in printing negatives the results can be distinctly appealing.
Originally posted by TomB_tx I find the Ilford films dry flatter and so handle better without the curl modern Kodak films have.
Some Kodak films had thicker bases, a classic example of this is T-max 100 in 120 format, with manual winding cameras the thicker base translated to greater flatness as the film was smashed flat against the film rails - this had to be changed later on to accommodate MF cameras with automatic winders - you could mess up the entire film transport mechanism, it couldn't handle the extra friction and you could burn the winder motor out.
Kodak 35mm films did curl more, but I find that they ultimately maintained their flatness better in film holders than the thinner ilford equivalents did.
