Originally posted by stevebrot Cool! I forgot that you were set up to actually measure the timing of the full shutter event as well as the light per exposure. Am I correct that ideally, the penumbra times should be constant at all speeds in a well-adjusted shutter?
Hi Steve,
You raise a few issues in one sentence!
The photodiode here is in the photo-current ( reverse bias ) mode
which has response time in microsecond range but ( I think)
the current is a logarithm of the incident photons.
Photodiode is mounted at the end of a "pipe" in black acetal of 1.2 mm dia and 10mm length
to give a grazing angle of 7 degree.
I originally made this to pick up scatter from ground glass on the Graflex cameras
when testing the leaf shutters and also the 4x5 focal plane shutter.
The "pipe" was pressed against the gg.
But I found it seems to work just as well on medium format shutters when
the ground glass is removed , and the "pipe" is approx at the focal plane ( ie "aerial focus")
I am fairly sure that the penumbra of the LF and MF leaf shutters
that i have measured here is dominated by the motion of the leaves, and not by my photodetector.
Today was the first time I measured a 35mm curtain shutter and i immediately noticed
1) a different shape to the rise and fall edges.
2) The brightness (40mm -M pancake wide open) was about 20%
of the brightness typically measured on a medium format lens.
3)There was a risk that the photodiode assembly would fall against
the Pentax MX shutter so i quickly measured the approx times and
did not record a trace off the storage scope.
So I have some work to do before measuring 35mm focal plane shutters at above about 1/125th second.
To truly measure the shutter speed/penumbra of a small film camera, I suppose I have to replicate:
The maximum angle of photons that will bring the film grains above recombination.
The floor brightness that will bring the film grains above recombination.
The sensor junction more accurately at the film plane but so it can't damage the shutter.
The photodiode current run through a transfer function to replicate film exposure.
regards
(Yikes, I hope Rupert and Otis don't get hold of this little diatribe!)
