10-08-2016, 03:54 AM   #1
Flash Off on Pentax *ist DL
I am able to turn off the flash on the camera using the appropriate setting, but I have one issue. Is it possible to use one of the other settings on the camera, such as macro, and also have the flash off at the same time? It seems to me I have to choose one of the settings and that's it!
Any advice most welcome.
10-08-2016, 08:56 AM   #2
If I remember correctly, if you go into the menu and set the flash so that it is off, (will not open automatically), The onboard flash will not open unless you open it yourself with the flash release button.
10-09-2016, 06:09 AM   #3
QuoteOriginally posted by bigdavephoto Quote
You most definitely put me on the right road. There is an Fn menu on the back of the camera. They refer to Flash Mode. One was Manual Discharge. When I selected that instead of Automatic Discharge I was able to use the top setting such as macro without the flash popping up.
Many thanks - very much appreciated
10-09-2016, 09:50 AM   #4
Your welcome. Glad I was able to help you.
camera, flash, pentax *ist, settings
Pentax ist DL powers off kaos0930 Pentax DSLR Discussion 2 09-15-2015 02:48 PM
Pentax ist DS and ist DL problem Neven Troubleshooting and Beginner Help 6 05-20-2015 09:15 AM
Pentax IST DL - Flash issue SamIV Pentax DSLR Discussion 5 11-11-2014 07:45 PM
IST DL Flash huntlg Troubleshooting and Beginner Help 4 01-22-2012 07:44 PM
*Ist DL and TTL flash Matjazz Pentax DSLR Discussion 28 01-15-2007 08:09 PM
All times are GMT -7. The time now is 07:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
