11-21-2016, 06:34 PM   #1
Are light leaks worth repairing?
Hi,
I have some photos from a camera I recently bought and some of them had light leaks.
Is it worth repairing? Can I repairs these by myself or is it better to get a professional to repair them?
11-21-2016, 07:39 PM   #2
arnold's Avatar
QuoteOriginally posted by danlam Quote
Hi,
It would really help if you told us what camera you have.
11-21-2016, 07:48 PM   #3
QuoteOriginally posted by arnold Quote
Hi Arnold,
It is a Pentax Asahi SP1000
11-21-2016, 08:47 PM   #4
Not a Number's Avatar
DIY replacements kits should be available and with a few exceptions are easy enough to replace. The kits are not very expensive and some include tools to help remove the old seals and comprehensive how-to guides.
Jon Goodman makes and sells probably the best kits available. You can find his contact information in this thread:
https://www.pentaxforums.com/forums/114-maintenance-repair-articles/297420-ps...-seal-kit.html
11-21-2016, 08:51 PM   #5
Cool thanks!
11-21-2016, 10:00 PM   #6
Helios 1984's Avatar
Light seals & mirror bumpers are easy to change, it just need patience and meticulousness. I did my Praktica with wool and self adhesive felt but for my Spotmatic I bought a kit from Jon Goodman (it was way less expensive and no brainer).
11-21-2016, 10:17 PM   #7
arnold's Avatar
Hi Arnold,
I have done many cameras this way. The light seals are easy to replace if you can find some foam or velvet sheet (adhesive backed if possible) about 2mm thick. You cut it into strips that will fit into the door grooves on the body. First you have to clean out the old grooves with a toothpick or bamboo skewer. Tape some paper over the insides of the camera so debris doesn't fall into the works, and hold the camera accordingly. Leave a small gap on the top right where the counter reset button sits in the groove. If you use adhesive back, wet it before sliding it into place so it doesn't grip and twist. The mirror bumper should also be done, and if you need details on that, let me know.
11-21-2016, 11:37 PM - 1 Like   #8
Otis Memorial Pentaxian
Jon Goodman's kits:
JGood21967@aol.com
Yes, there are other ways to do it, but Jon charges $10 including shipping and includes easy to follow instructions specific to your camera. His materials are top notch.
11-22-2016, 08:51 AM   #9
Jon Goodman's kits:
JGood21967@aol.com
And $11.50 international :-)
camera, leaks, light, light leaks, photo
SV worth repairing? murrelet Pentax Film SLR Discussion 11 07-17-2018 12:53 PM
Oil on aperture blades, when is it worth repairing? ZombieArmy Pentax SLR Lens Discussion 12 09-04-2015 11:54 AM
Replicate Light Leaks on Medium Format Film? Hannican Photographic Technique 5 02-02-2015 06:05 PM
Worth repairing? Syb Pentax SLR Lens Discussion 5 11-25-2007 05:18 AM
This lens worth repairing? bdphoto Pentax SLR Lens Discussion 5 02-03-2007 03:44 PM
All times are GMT -7. The time now is 11:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
