Originally posted by pentaxian_tmb I have a refurbed pentax MESuper. Want to start shooting film, but not sure how best to go about it. I have shot a couple of rolls, but already lost 2 rolls of film because they didn't catch on the winder.
As far as development is concerned, I have a scanner with settings for photo negative and a negative frame holder. Is it good enough to just get the negatives developed and then scan them into the computer? Do I need to tell the developer to add exposure comp or is that all done in post when I scan it like digital?
Can anyone get me started?
Exposure compensation during developing is called "pushing" or "pulling". "Pushing" refers to the practice of exposing the film as if it were a higher ISO than it really is. For example, you are using film rated as ISO 100, but you expose it as if it were 200. This is pushing it one stop. If you exposed as if it were 400, you would pushing two stops. Effectively, you must do this for the entire roll.
You then tell the lab to push the development one or two stops. They do this by leaving the film in the developer longer than the normal time. This can only be done by a real lab, that does "dip and dunk" processing. The one-hour places, with their automated machines can not do this. The machines are pretty much set. If you develop your own film, you have control over how long the film stay in the developer.
Pulling is less common and involves just the opposite. You expose ISO 200 film as if it were 100 or 50. You then leave it in the developer for LESS time than normal.
I suggest that, to get started, you do not worry about pushing or pulling the development. Just shoot at the rated speed. If you still have any place that can process you film with a machine, it will probably be cheaper than paying a real lab, even if you don't push the speed. Cost should be an issue, because you're probably going to need to shoot a fair amount of film to get the hang of things.
As for scanning, your equipment is probably good enough to start with. You can probably scan at the equivalent of 6-10 megapixels, maybe more. While you're not going to make any wall-sized murals at that resolution, I have gotten excellent 16 x 20 prints from my 10 megapixel K10d.
If you decide to continue shooting film, you can always invest in a better scanner or your own developing equipment.
BTW, developing black and white film is a snap. Color print film is not much harder.
