The issue:
The light meter was going crazy, but it worked in some way. So I decided to unmount the top plate and as the wires were to weak in soldering and accidentally I have broken the board, so, I want to replace the board with new one that has holes for solid soldering connection. I have already designed the board with same dimensions into my favorite CAD.
One of the resistor (12k ohm) is broken, it has one leg missing.
The goal is to fix the light meter, replacing the board and connecting everything to the right place.
These are some of the pictures:
If you notice better in the picture above, there are 2 holes whose belong to 12k ohm broken resistor.
The board
Above, Spotmatif F - Wiring and Circuit. The board represented is different ?!?
K1000 Schematic
My new design
Bottom view of my design
