Originally posted by Dalboyne Hi! I need to replace the light seals and mirror damper in my recently-acqired MX. I've got a selection of sponge foam, but would really appreciate some photos of how the seals should look when done properly?
Many thanks!
Ian
There is not much one can show. The door has a ridge which slots into grooves at the top and bottom of the camera. You need to scrape out old seals with a toothpick, holding the camera so that the debris falls out of, not into, the camera. You need to cut strips of adhesive backed back foam or felt about 1mm+ wide and between 1 and 2 mm deep to fit these slots. Don't cover the film counter reset button at the top slot. The mirror bumper should allow for the latch on the screen door to open,
