02-27-2017, 04:45 PM   #1
What to replace ZX-5N with??
I just ordered a Pentax Refconverter-A because I was planning to use it with my ZX-5N mounted to my wheelchair camera mount. My ZX-5N has been in the camera cabinet for nearly a year without use. In preparation for the refconverter arriving, I pulled out my ZX-5N, put the batteries in, fired a test shot... and the mirror stuck. Broken mirror motor gear!
I understand Eric Hendrickson no longer repairs this?
My dilemma now is, what to replace the ZX-5N with? I need to be able to use the Refconverter-A, as well as a Pentax Cable Switch F.
My initial thought is to find a PZ-1p... but the ability to use AA batteries is a huge benefit? Should I try a MZ-3 or ZX-5N again and hope it lasts?
02-27-2017, 04:55 PM   #2
My ZX-5N died in the same way this year. I have a PZ-1p and some digital bodies and went back to the PZ-1p to shoot film. Assuming you don't want digital, either the PZ-1p or MZ-S would be good. Battery life on the PZ-1p is very good but the CR5 batteries are harder to find. The MZ-S was the last high end film body and uses the CR2 batteries (a little easier to find) and would be compatible with your accessories. Of course, digital is another way to go but to ensure continuity the film cameras are still great.
02-27-2017, 05:01 PM   #3
QuoteOriginally posted by Pentax Syntax Quote
The MZ-S was the last high end film body and would be compatible with your accessories.
I think the MZ-S isn't compatible with the Cable Switch F?
02-27-2017, 05:03 PM   #4
I had both for a while but can't remember. You could be right that they switched to the modern remote.
Just checked and yes you are correct they switched away from that cable with the MZ-S. So PZ-1p it is......
02-27-2017, 05:17 PM - 1 Like   #5
Not a Number's Avatar
See this thread on ordering a replacement gear (from Germany). Maybe if you have the gear, Eric can replace it for you. There are also DIY instructions in the thread.
MZ5n mirror blocked, service manual? - Page 7 - PentaxForums.com
02-27-2017, 05:40 PM   #6
QuoteOriginally posted by Swift1 Quote
I'm a big fan of AA batteries, but found a rechargable battery for my PZ-1p, and I recommend that set up.
02-28-2017, 12:23 PM   #7
QuoteOriginally posted by lithedreamer Quote
What are you using for a rechargeable battery?
02-28-2017, 01:23 PM   #8
Colton,
You live in the Portland area correct ? If so, you might see if Paul at Advanced Camera can fix your camera, he's a old Pentax tech, really knows what he's doing. He's done 12 Pentax SLR's for me, all work great with no problems, very reasonable pricing.
Advance Camera Repair
Another option if you really want a PZ1p, I have a extra one I picked from KEH in good working condition a few months ago. You can have it for whatever I paid for it plus you can have the F35-70 I put on it as a body cap.
02-28-2017, 01:48 PM   #9
QuoteOriginally posted by longbow Quote
Colton,
Thanks.
I'm in Southern Oregon, but I've used Advanced Camera before, I'll give them a call.
I actually just ordered a really clean Z-1p with "grip" from Japan. I'll keep y'all posted on how that goes.
02-28-2017, 01:54 PM - 1 Like   #10
Thanks.
Great !!
Hope it works out for you.
02-28-2017, 02:22 PM   #11
Thanks.
The problem are parts. It looks like the supply of replacement motors with the metal gear for the MZ/ZX series dried up a couple years ago. That's probably why Eric doesn't service these. Hence the link I posted for a suitable replacement gear. You just need a pinion gear puller/pusher to remove the old gear and install the new one. You can improvise but the proper tools make it much easier.
02-28-2017, 03:31 PM - 1 Like   #12
It looks like Amazon doesn't sell them anymore (or is at best sold out) but here's the one I have:
https://www.amazon.com/PowerSmart-DURACELL-ENERGIZER-FUJIFILM-PANASONIC/dp/B...ntaxforums-20&
It was $24 after shipping.
02-28-2017, 03:43 PM   #13
DIY service is pretty much out of question for me
02-28-2017, 05:06 PM   #14
Well you can contact Advance and Eric and ask them if the can get parts for it - most likely the mirror motor. In Eric's case ask him if you can supply a replacement gear if he could fix it.
Or go with one of the other suggested bodies
I have an MZ-50 myself with both the broken flash lift and mirror lockup problems. I didn't think it worth my time to do a DIY fix on the gear problem. I tried to fix the flash popup but it appears the spring is broken as well as the pivot part. I might just cannibalize the notorious aperture solenoid and offer it (the solenoid) on the marketplace.
03-01-2017, 08:48 PM   #15
Me too.
Hey, almost the same thing happened to me this week, and I've also been looking at gear replacement procedures, MZ-S, and PZ-1p. Hope your Z-1p works out for you.
---------- Post added 03-01-2017 at 09:50 PM ----------
Colton,
Longbow, I'd be interested in your PZ1p. Can you send me what you want for it in a PM? Do you have a manual for it? I've got lenses, mostly interested in the body and instructions. Thanks!
batteries, body, camera, hope, instructions, lenses, mirror, pentax, pm, post, pz1p, thanks, zx-5n
ZX-5n disassembly with pictures Sluggo Film SLRs and Compact Film Cameras 25 05-02-2019 07:54 PM
For Sale - Sold: Very Low Mileage ZX-5N (MZ-5N) w/ Data Back Fg w/ AA Battery Pack Fg fwcetus Sold Items 2 01-09-2016 09:14 PM
focusing screen of MZ-5n / ZX-5n : can it be change ? aurele Film SLRs and Compact Film Cameras 10 11-02-2012 11:15 AM
All times are GMT -7. The time now is 01:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
