03-01-2017, 01:15 PM   #1
Do the Pentax M bodies all share the same back?
I recently acquired a really clean Pentax ME body. Most of it looks nearly pristine except that the back is pretty scratched up, so I want to eventually replace it. Does anyone know if the film doors are interchangeable on the M series bodies?
03-01-2017, 01:35 PM   #2
Digitalis's Avatar
I recall there being a date back for the ME super* - so the original back should be easily removable. The ME super back plate may not be interchangeable with other models though.
*used for recording the year/month/day a photograph was taken.
03-01-2017, 02:20 PM   #3
gofour3's Avatar
The ME/ME Super should be the same, as they shared a dial data back "ME" as indicated above.
The MX has a different back, so stick to the ME/ME Super.
Phil.
03-01-2017, 07:30 PM   #4
QuoteOriginally posted by gofour3 Quote
Phil.
Thanks guys. I forgot about the data back for the M bodies. It looks like the MV1 and MG can use the same data back, so maybe I'll look out for one of those.
03-01-2017, 09:01 PM   #5
The Super Program back will also interchange with the ME and ME Super. The leatherette will be a bit different in texture though. I'm not sure about the MV, MG, or others though. Maybe someone else will comment on those. I can also confirm Phil's claim that the MX has a different back that won't interchange with the others.
bodies, bodies all share, pentax, pentax m bodies, share
Quickie: Should the pins on the D-BG5 all sit at the same resting height? BaconBehemoth Troubleshooting and Beginner Help 3 01-09-2017 07:46 PM
Do the 645D and 645z share the same battery ? larkis Pentax Medium Format 2 09-23-2014 02:35 AM
(DIY help) Do all softboxes have the same mount? dstructor Photographic Technique 6 12-26-2012 03:53 PM
K-5 II and K-30 do not Share the Same AF Module Class A Pentax DSLR Discussion 8 09-19-2012 11:02 PM
Are All m-50mm f/2 lenses the same? lawsonstone Pentax SLR Lens Discussion 6 10-30-2009 03:46 PM
All times are GMT -7. The time now is 03:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
