03-19-2017, 12:40 PM   #1
builttospill's Avatar
MZ Plastic Gear Replacement
I received a reply from Eric yesterday saying he didn't have parts to repair the mirror getting stuck on my MZ-3. The spring that holds up the pop-up flash is either disconnected or broken too. Im guessing the mirror problem is being caused by the split plastic gear.
Does anyone know where I can get a metal gear, or is there someone else who does these repairs and has parts? Anyone here willing to fix these issues?
03-19-2017, 01:49 PM   #2
beachgardener's Avatar
There are stacks of these for sale on ebay, for parts, as is, etc. I would guess mostly they have the same problems.
03-19-2017, 02:10 PM   #3
ChrisPlatt's Avatar
There have been several threads here with repair instructions, including a source for the replacement brass gear.
Here's the first one I came across:
https://www.pentaxforums.com/forums/8-pentax-film-slr-discussion/39450-mz5n-mirror-blocked-service-manual.html
Good luck if you attempt the repair.
Chris
03-19-2017, 03:57 PM   #4
Not a Number's Avatar
You can buy the pivot for the flash which is what normally breaks from US Camera. Since it's the same part it will eventually break again. Both this part and the spring are broken on my MZ-50 so a DIY repair was unsuccessful. See the various threads on PF for DIY repair ideas. I tried the little brass/aluminum tube fix but because the spring is broken too it didn't work.
Genuine Pentax Flash Head Left Pivot Frame ZX10 ZX30 ZXM ZX5 ZX5n Replacement Spare Repair Part | 27250-q701 | uscamera.com
03-20-2017, 04:44 PM   #5
Thanks for the links, guys. I ordered a brass gear for the mirror motor. In the camera reviews, one says the MZ/ZX-60 has a brass gear, and another review says it still has plastic. Can anybody confirm which one it is?
Also, still looking for a volunteer to perform the repairs for a small fee. I have a ZX-50 to donate for flash pieces.
03-20-2017, 06:59 PM   #6
I'm still wondering if the MZ-S has the brass gear? That is a camera I have thought about purchasing.
03-21-2017, 12:52 AM   #7
ChrisPlatt's Avatar
The MZ-S was introduced later and was positioned as a professional model.
It bears little resemblance to the other MZ/ZX cameras except in name.
I'd be surprised if it shares the same multifunction motor. Eric would know.
Chris
03-21-2017, 03:31 AM   #8
It's not the motor that fails but the plastic gear. The replacement part was a motor with a brass gear. Presumably it is just as easy to replace the motor and gear rather than remove the motor, repace gear and reinstall motor. I can hear the motor running in my MZ-50 - continuously since the gear isn't turning to complete the cycle.
03-21-2017, 10:12 AM   #9
Yeah, that's what my MZ-3 is doing, the motor is making a strange noise and the mirror stays up. I can physically return the mirror to its lowered position, but when I take another photo, the mirror stays up again.
I can't find the motor available anywhere, so I just ordered the gear. I'd rather replace the entire motor, but...
03-21-2017, 02:00 PM   #10
ChrisPlatt's Avatar
Later the replacement part supplied by Pentax was motor with brass gear.
Eric installed one of these units in the MZ-3 I had years ago.
Pressing the new brass gear onto the motor might be tricky.
Be careful not to damage the motor. Nothing in these cameras is overbuilt.
Chris
03-25-2017, 09:47 AM   #11
chickentender's Avatar
I've heard of these issues but haven't paid them much heed as of yet because my MZ-3 has worked perfectly thus far. Sounds as if I ought to be a bit proactive in the part procurement department. Was it one of you folks that just brought it to mind on a Flickr post recently??
07-27-2017, 07:09 AM - 1 Like   #12
I successfully put one of the brass gears on my MZ-3. The level of force fit is "just right", so I don't see any risk of damaging the motor. It's very fiddly doing it with tweezers, but can be done. Nice not having to unsolder many wires from flex print.
07-28-2017, 09:31 AM   #13
QuoteOriginally posted by John Shriver Quote
Can you post more details on the process? What steps did you take, did you glue the gear, any challenges to be aware of, etc?
07-28-2017, 01:36 PM   #14
Just press the brass gear on. You want to apply force on both ends of the drive shaft which should extend past the bearings on either end of the motor. Make sure the gear clears the bearing (you don't push it on too far).
07-29-2017, 02:10 AM   #15
Ani
I just fixed my Mz-3 a week ago, turned out it already had a brass gear (I bought it from jpn might have been fixed before?) but the issue was part of the mirror return leaver. The lowest portion that acts on the cam on the great gear was broken. A little creativity and super glue and it's back in working order.
Just home processed a roll from it and all's looking ok.
gear, mirror, mz plastic gear, plastic
Pentax Da35mm 2.4 plastic lens vs Da 50mm 1.8 plastic lens fevbusch Pentax SLR Lens Discussion 24 01-26-2014 06:49 PM
Pentax 55-300mm DA L plastic mount repair/replacement Respectedent Pentax SLR Lens Discussion 43 12-29-2013 06:56 PM
The difference between MZ-5, MZ-7 and MZ-10? Raffwal Pentax Film SLR Discussion 7 02-11-2012 05:03 PM
Wanted - Acquired: any of Pentax MZ-S, Z-1P, Z-1,MZ-3, MZ-5N, MZ-5, MZ-6 tianyawoya Sold Items 1 07-10-2010 08:13 AM
Hands-On Comparison MZ-5n vs MZ-L(6) vs MZ-S k100d Pentax Film SLR Discussion 37 02-01-2009 11:25 PM
All times are GMT -7. The time now is 11:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
