Originally posted by jopenmx Thanks a lot for all such interesting information ĦĦĦ . After a carefully study of the flash diagram I have to recognize that you was right concerning the spring which pops up the flash. Don´t worry for the bad quality of the owner´s manual , since I still conserve the original one ( in spanish ) .
I wasn´t able to include some photos and files ( leaflets, and manual in english, ) concerning Z-1p But if you wish some of them , please let me know your mail adress and will send you.
Regards
There is a small screw slightly above where the spring is supposed to be attached it's a small stretch to hook the spring there. It holds the pop up flash quite firmly in the extended position. The problem I have is that when the flash goes down it is supposed to catch on something which latches it closed and pressing the flash button should unlatch it and the spring pull the flash to the upright position. I cannot figure how that works, I've had a knack for figuring out systems since I was a kid and being defeated by this is really annoying.
I knew there was a problem with the pop up flash mechanism, when I bought the camera and i didn't think it would bother me, but honestly it does
One thing the diagram does show is that just one spring attaches to that bar so the extra hole seems to be misleading. Although why take the time to create a hole which is not used? That makes zero sense unless the part is designed to be used in a different camera, there is always a reason behind something in engineering.
